Ported inlet manifold
Home ported inlet manifold. Standard MH/2G hydro head inlet manifold ported to increase the exit bores akin to the GK manifolds. Seemed to work fine on the car in conjunction with a GT cam and would be perfect for a weber 32/34 dmtl. The only downside is that the port for the servo vacuum connection got snapped off. I repaired this with some chemical metal and a new brass outlet and it seems to have done the trick, when it was on the car the repair didn't leak as far as I was aware.
I need this gone as i don't have a car with a single carb anymore, pics available. £10 plus postage
  • Views 118
