6n2 TDi or Lupo GTi Pedalbox
I’m looking for a Hydraulic pedal box from either a 6n2 TDi or Lupo GTi
Ideally I would also like the hydraulic line with the matching master cylinders/servo, the connector at the gearbox side and the vacuum line that goes from the clutch cylinder to the brake reservoir (I don’t mind purchasing the brake reservoir aswell)
Here’s a diagram of the hydraulic line, cylinders and random extras i need with the pedal box (everything at the top of the pic, essentially all the parts between 23 - 31)
Although the pedal box on its own will be OK
  • Views 483
