VCDS near Barnsley, South Yorkshire
Hi every one.
Having a couple of issues with my 9n and wondered if there was any one local that had access to VCDS, apparently thats the new term for Vag Com? Willing to pay beer money etc.
Problems I'm having trouble with are the brake pad wear sensor light, basically i want it recoding and turning off, the numpty who changed my front pads last decided to cut the wire and bridge it before the connector plug for the sensor, right at the top millemeters from the abs wires making it impossible to to get a good conection now.
And secondly I'm having trouble with the V68 temp flap motor and need the basic settings doing as I'm in the process of fitting a new one due to the common problem of heater blowing hot 24/7.
Thanks in anticipation.
Dave
  • Views 564
