Ignorant passengers
The airbag would likely have given him a facial injury, if just a broken nose, inflamed skin.. Possibly minor hand or arm injury.
So with the airbag not going off, due to there not being a 'hard' enough shockwave into the chassis, you have to wonder what injuries he did sustain - and if they were worse?
Because judging from that picture, he'd have only sustained an injury if he was picking his nose at the time!
  • Replies 67
  • Views 3.6k
index finger lodged in his frontal lobe?
I don't have faith in any airbags, when I hit a deer in my mk3 GTI they didn't go off. :/
well they clearly weren't needed because you're here... unless you sustained neck/head injuries......
298403_10150430915746142_565076141_10798
How were they not needed?
hmmmm, yeh would still say not needed, airbags are designed to deploy to prevent you from sustaining serious injury, granted that must have been a hard hit but not enough to injure yourself much, or did you?
Claims he's been in a bad crash..
..shows a car with cosmetic damage
taxed worst looking.... :ninja:
Airbag sensors need certain conditions to fire.
If they had in that little bump you've had in that golf fired, they would most likely have caused you a pretty serious injury.
It is entirely possible to smash up the entire front of a car (like the picture shows) and not have the air bags fire, mainly as the Airbag ECU has picked up on certain criteria needed not being right, as far as the Airbag controller was concerned that cosmetic damage was most likely the equivalent of hitting a deep pothole, at no point was there any deformation of the body structure to trigger those sensors and hitting a deer would not cause severe deceleration.
See Deer @ 60MPH, Slam on brakes, hit deer (a light and easy to move object), car carries on travelling for 20+ yards, declaration is slow = No bags
See Parked Car @ 60MPH, Slam on brakes, hit Car (Heavy and solid Object), car stops suddenly, declaration is fast = Bags/countermeasure's triggered
I bet your airbag system thought someone coughed in your car.
I can't be ringed to read this thread but people who winge about my car don't get a lift. They can take the bus or a taxi.
Is your car particularly dodge ?
Its not rapey.
Its not rapey.
Surely everything is a little bit?
When did claim I was in bad crash?
I honestly thought that the airbags should have gone off in the crash I was in. They didn't go off.
Neither I or my passenger was badly injured. I did not get whiplash or anything.
The only I posted the image was because i would have thought the airbags Could or maybe should have gone off.
Indeed Steve, but when they do work they can do more harm than good - i know someone who has just last week sustained injuries, including a broken arm, by an airbag in a minor shunt where the airbag wasn't needed.
If I ever owned a modern car with an airbag, I'd have it removed. They are incredibly dangerous in my eyes.
If I had a head-on crash, I'm sure I would have been thankful for one but I imagine (particularly in my BMW) I'm more likely to leave a road sideways than crash head-on. Having said that, there are even crashes you can have where not having your seatbelt on can genuinely save your life!
[A friend of mine was distracted through lighting a cigarette whilst speeding down an on-slip. He mounted the verge, rolled the car and was neatly deposited on the embankment as his car rolled down the road. If he had been wearing a seatbelt, he may well have died. Even I am always apprehensive wearing a seatbelt in icy conditions as you can crash at low speeds when you've lost control. It makes more sense to be sliding on your arse in some instances than sat in an out of control car. No doubt people will vehemently disagree with me!]
Airbags very often give you frozen nitrogen burns on your wrists as they go off.
Regardless of what you strike (you can set one off at 5 mph!), this is how powerful they can be http://www.youtube.com/watch?v=uUZJkti1A3M
Some C*** on a bicylce tapped on my window at the traffic lights and said i might want to look at my suspension because it looks as if it's collapsed :x
I was actually offended
Heres how it is lads.
As an old bastard :-).......we were taught a phrase when we were young.......
Third class driving is better than first class walking......
End of :-)
Well having seen this..
.. knowing an airbag is seriously violent and usually causes injury when it goes off in your face, you now know why they're set up so that they don't go off unless you're subjected to serious force, and genuinely need such a counter-force as literally a last resort effort to save life.
Airbags are not the first form of defence despite their soft name, the first stage of the crumple zones should act first to cushion the impact suitably - the bodyshell of your car sustained no damage so no such forces were present in your case, thankfully.
Now had you swerved to miss the deer, and subsequently hit a tree instead..
my mates went off in his decked clio down a bumpy road hahaha
I was misinformed. Apparently you have to be traveling at 14mph into an unyielding object to make them go off. When they do so, they travel at you at 144mph - 210mph. Pre-1997 airbags are more dangerous as they are rated at 1200 lb of pressure rather than 900 lb.
In any case, I really wouldn't want them in my car! Thank you retro cars!
