Sony CDX-GT50UI CD/MP3/USB Head Unit
Evening All
My Sister has just changed the stereo in her car so this is her old one. Its in fully working order and comes with the wiring harness, aerial adaptor and cage. The face plate has a very minor amount of scratching from living in her handbag but otherwise all is good. Here is the spec of the unit.
The unique CDX-GT50UI provides you with direct iPod connectivity, allowing you to have full control of your iPod and also charge it while driving. The front USB input lets you connect a mass storage device such as a portable hard drive, or any other portable MP3 player or Walkman with the ability to control tracks on the head unit. This is truely the ultimate headunit for those with an extensive music library.
iPod Direct Connectivity- Connect your iPod directly to the headunit for full speed functionality and control (no optional lead is required!)
MP3/WMA/ATRAC/AAC PlaybackFront USB Input For Memory Stick 24-bit DAC (Digital / Analog Converter)
Rear out / Sub Out Switchable
4 x 52W Max Power Output
3.5mm Front Panel Input
Subwoofer Pre-out
CD Changer Control
Piano Black Faceplate
These retailed at £240 when new. My sister is asking for £70 posted.
Sammo
  • Views 185
