Sam's '90 Breadvan
How much was you after for the stage 2 then?
Don't know. It's obviously well used but the thing's rock solid - what would be a reasonable price?
  • Replies 89
  • Views 17k
  • teaser? This isn't a mock up anymore.
  • So, I kinda shot myself in the foot, was hoping to be all "yeah I've done this much" and then unveil my awesome newly mounted engine, but as always time runs away from you and I'm still going slow. I
  • erixtar1992
    erixtar1992
    love this
Not a lot happening as parents have been moving house, towed my car there yesterday, can continue when they have finished unpacking and stuff.
In the mean time, I have been working on the dashboard - I will be smoothing it out to remove the texture, making it shorter and ultimately making a carbon fibre copy of it.
526809_10201675761362856_1025469249_n.jp
Also, I fucked up the drivers side wing - because none of the arches were obvious as to which corner went where, the two fronts didn't match. ripped it off and selected the correct one.
1002157_10201675760042823_1361726549_n.j
Just awaiting the body filler then I can get smoothing.
Any updates on this? Been waiting long enough I feel haha :)
Should be a couple of 'larger' updates coming in towards the new year :)
But that's too far away! :( give me a teaser of what's to come
1231563_10201897351182463_778715074_n.jp
I'll be brief as I'm writing this for the second time.
Spare wheel well is gone:
Also stripped out the roof lining and whatnot, I will eventually have the lining replaced with carbon fibre and the sunroof controls moved to the dash (excuse the glitchy panorama):
1457612_10151975628772270_843705020_n.jp
through plenty of Google.de and hours of searching, found a nice stash of photos to compare how the Germans have put in a 1.8 t (fuck paying a grand for a dodgy looking salzmann kit)
Lopped the front end off:
Cut up the chassis arm, as the 1.8 t will require golf mk1 engine mounts.
Heres a comparison to a German car I found online:
Started roughing out the shapes to fabricate:
Used dad's new plasma cutter with 3mm mild steel (badass little thing, cut out the shapes in less than 5 minutes)
Partly welded into place as I ran out of daylight, but will be getting thicker steel for the mounts, then will starting on the passenger side.
Strengthening will be through a roll cage and subframe similar to the PPP stage three (although I will be wider to compensate for the sump) and I'm hoping to integrate an adjustable anti roll bar. The front beam is going to be replaced with a bolt in removable cross member and the front panel will also be removable for access.
Aims for christmas/new year:
- Suspension turrets are going to be replaced to accommodate mk1 golf camber plates and coilovers
- Passenger side chassis rail will be modified to accommodate the mk1 golf mounts
- cross member brace will be made
- engine mounted
OH YEAH
- No more lies about my progress! It's just going to be a slow project I've come to accept :(
Edited by samwii
Long term plans:
Suspension:
- Golf mk1 Damp/rebound adjustable coilovers with polo mk2 steering arm
- Golf mk1 camber plates
- Golf mk1 engine mounts (poly for stiffness)
- stiff suspension bushings all round
- PPP stage 3 style subframe
- Modified wishbones to integrate an adjustable ARB
Engine:
- AGU head Ported/Polished
- 1.9 tdi Crank (longer stroke)
- JE pistons (oversized to bring engine to 2.0)
- Forged rods
- ARP headbolts
- 500cc/min injectors
- IHI VF34 turbo (Subaru STI)
Aiming between 320 and 350BHP
Chassis:
- Hispec 4 pot calipers up front with EBC pads
- Black diamond discs
- not sure on wheels yet (wide)
- Toyo R888 tyres
- Seam weld chassis
- Roll cage
New year updates?
Unfortunately not a lot as I've just come out of surgery! got some pretty wicked scars though
1452254_10203002162562057_1765355593_n.j
Anyways, with the car:
Lopped off the back arch as it's going to be converted to round arches
1525305_10203002094960367_1881122498_n.j
1526807_10203002095000368_638600257_n.jp
been mocking up the finished result (it's nice to dream haha)
1558484_10203002062719561_1937168187_n.j
Cut up the passenger side chassis rail, getting ready for the new mount to be made and welded in:
1493192_10203002256764412_1847834155_n.j
should look something along the lines of this:
1013743_10203002143361577_819094934_n.jp
more mocking up:
1607017_10203002145321626_1367444588_n.j
Managed to source the engine mounts, just saving up for them, so hopefully the engine will be in soon!
Shit man! That scars rad though dude, playing the sympathy card with the females? ;) haha. Love the mocks you have done, for a second I actually thought they were real :| realllly can't wait for more updates, sad about the rear aches though :(
love this
Edited by erixtar1992
love this
Cheers dude. So far seems to be the mockup capturing people's hearts, so it's what I'm aiming for.
Great news, because of surgery I'm under supervision of my parents for the next month which means I'm at there place. So everyday from now on I have access to welders, plasma cutters and all things dangerous :) So hopefully, expect some more rapid updates.
Oh, and for shits and giggles. something a bit more lairy...
1609813_10203047548136668_1576695213_n.j
Edited by samwii
haha excellent! that frontend better be done soon so you can make me one! hahaha
Hahaha, good things come to those who wait ;)
In the mean time, I've been working out my wheel calculations. Looking at minilite wheels, 13x8j at the front and 13x9j at the rears. Offset calculator online put out some interesting results. The tyres are going to be Kumho V70, as they are the only ones with the sizes I want. And to be honest, they are so wide I doubt grip will be an issue... Originals are left, aftermarket are right
fronts:
1538826_10203050372807283_551568354_n.jp
Rears:
1069817_10203050372767282_1897626714_n.j
The rears will apparently stick out 3.8" farther lol. Hope these arches will cover them!
fronts:
1012876_10203050408328171_1850112374_n.j
rears:
1506688_10203050408368172_932397466_n.jp
Edited by samwii
