Doors have dropped
Is there any way to adjust the doors on my 6n as they seem to drop slightly when they are opened. They catch on the top and they sometimes pull the door cards off when opened.
Any help is appreciated 8-)
  • Replies 9
  • Views 1.4k
Tried to get an exploded diagram of the hinge on here from ETKA but
i can't get it to copy the picture to here...sorry.
Edited by buster.g40
not garenteed to work but try new hinge pins, there cheap and this sometimes helps, keep them well greased if they do work.
Attached a diagram for you.
Check over the screws around the hinge, make sure the are tight on both the body and the door!
It might be that you've bent the hinge or the hinge is failing etc
Cant get hinge pins from vw anymore. I've already tried lol.
Pikey solution: block of wood on jack, open door so its above the wood, start jacking, bend pins and hinges into correct position................. Profit.
*I do not take any responsibilty for anyone who is pikey enough to give this a bash.
Cheers for that daveb :) that is a great help.
leonh - all I could do when reading your reply was :lol:
I didn't think about doing when i had my mk2 :ninja:
No worries man ;d
Didn't think, just did it eh? ;)
My driver side door was damage when i got my 6N and i changed the door, during changing it i had the prob of doors hanging when opening and lifting when closing.
Problem was the hinges that was fixed to the door wasn't in perfect alignment with the hinges on the body of the car. solution, loosen the screws (Not completly, just enough for it to move) for the hinges on the door, not on the car body.
wiggle and adjust the door till it sits perfectly, then tighten the pins that sits into the hinges hole (The ones that holds the door on, then tighten the hinges firmy back to the door.
You will need a either a short torx bit on a angled driver or an angled torx wrench.
Get a mate to lift the door while you tighten
