wet floor
gave the car a wash and hoover today, whilst hoovering i noticed the drivers front and rear footwells were wet. a while back i had the clutch cable replaced but the seal was never fitted properly for the hole in the bulkhead, could this bee the problem, also it has been parked on my drive which is pretty steep, maybe this has added to the problem.
also i have noticed water marks on the two rear corners of the headlining, does the sunroof have drainage holes at the back, i've noticed the two at the front or could it be coming in from the aerial.
thanks
  • Views 548
