Any Ford KA owners with a user manual?
hold the "reset tripometer" button then turn the key to stand by. it should give you some fault codes. Just google them and you'll have an answer!
Happened to my Mrs, i tried leaving battery off over night, fixing the actual problem (fooked spark plug) and reset procedures, but ended up having the ECU reset on an MOT.
What do you mean by standby mode buddy? just the 1st ignition click?
Mates got a KA with a misfire, even after changing the entire ignition system, servicing and redexing a full tank, and we cant work out whats up with it. :?
yeah just first click. should say "test" on tthe tripometer.
then press the reset button to scroll through all the codes.
  • Replies 25
  • Views 6k
