How to replace an electric mirror switch on a 6n2
On my 6n2 the little knob on the electric mirror switch has snapped off. I have purchased a new switch but I'm unsure about how to take the broken one off and put the new one on. Can anyone help?
Thanks.
  • Replies 5
  • Views 5.1k
  • You have to take the door card off because of the wiring. The switch is attached on the other side of the door card. Buts its very simple...
I un screwed the screw that was keeping the doorcard on but the door card wouldn't come off. It felt like it was stuck on by some thing. Is this because there is more than one screw that you have to undo or is it because you have to just pull the door card off?
It depends if yuo have electric windows or not.
Manual windows you:
-remove window winder.
-remove two bolts behind the grab handle
-remove the screw near the wing mirror
-remove the lock pin
-pull door card off
Electric windows obviously you don't do the first step :retard:
The door card is mainly held in place by grommit sort of things that just pull off, but be carefull not to loose them or you will have a rattly door!!!!! :lol:
you dont need to remove the door card to change it. Just carefully get a screw driver with a cloth and put it in the recess were the chrome handle is and prize it
Just done it that way. Thanks man :)
