Liam P Carter's 9n
They were once fitted wrong - forked out loads to refit the standard suspension and CBA doing it again. Wait antill the next car in August
  • Replies 346
  • Views 51.9k
  • LiamMk6Polo
    LiamMk6Polo
    Polo's gone :( New car has arrived.. Check it out in the none polo owners section :)
the coilies were?! fair enough mate, will the next car be 9n shaped? :(
Yes bud, on these they are a two peace top mount, rubber and a bearing, the bearing was missing allowing the Coilover spring to chew the ruber mount. Knock and making steering hard so had to do something about it, new top mounts, front springs and drop link, plus the labour even tho I was working on the car.
The cars going to be replaced if can be afforded for a 9n3 or a mk5/mk6 golf..
Say goodbye to this peace of shit!!
sad to hear you've lost the love for it man :/
9n3 or mk5 would be dope though, my Dad is selling an a4 avant (b5) if you're interested ;)
There's alot of Problems with it and I just give up. I'm not gonna get it back so I don't care.
She's a shed and she knows it.
Owned the car just over a year and it has been a love hate relationship.
hi mate just wondering if you have any clue why my polo is misfiring again its not long had a new coilpack due to misfiring before but cant understand why its doing it again.. plugged vag-com in but its not finding any fault codes as my engine light is not on but cant find out why its doing it.. its misfiring on idle but fine when its running it also bogs down and chugs when getting up to speed.. any help is good thanks buddy :?
Did you change all 3 coil packs? Or just the cylinder which previously miss fired?
Just the coil pack in the cylinder that was miss firing
Try your throttle body quite common on these, remove and clean with carb cleaner as they get full of carbon deposits. If not try swopping a good coil around, you could have a defective cylinder, so leaking under compression or just another faulty coilpack but hasn't failed to put a light on. 3 cylinders are common for being crap aha. Never again!!
FOR SALE WHO EVER IS BRAVE ENOUGH TO PURCHASE IT
Price? Swaps?
Thanks buddy... Really need to get it sorted now.. Making me look like I'm a crap driver by kangerooing down the road trying to bog down lmaoo.. Thanks again mate
I'm after £2500 for it. Covered 66k, 2004 plate, slight bits of body work but it's a 8 year old car. 1.2L. Just had a new coil spring and droplink, coil pack and a service 6k ago.- including spark plugs air filter, pollen filter, oil filter, oil.
Can be done a deal on it with existing parts left over ie Coilovers etc. after cash really...
Keelan9n - sounds to me like your car might be ready to go bang, not to scare you but they are common to go because of the close tolerances etc. alot of pressure in a 3cylinder and normally they can drop pressure in a cylinder makes them run ruff like a misfire. Advise to get a cylinder leakage test so you can see if you have a defective cylinder. If you do, scrap the engine and change it!! Recommend replacing It with a 4cylinder 1.4 instead of a 3pot. Just make sure it's not a 16v FSI as they eat the timing chain tensioners. Common problems with the 1.2's.. That's why they have finally gone back to a 4pot on the new polo's and Audi's
Hope this helps
P.S. HURRY THE FLYING F*CK UP SUMMER - B*TCH's NEED TO BE ROLLING IN THIS TING!!
This!
When the summer comes can you send some of the bitches my way so they can roll in (on?!) my ting. Many thanks.
Now it's standard and for sale I have a grievance regarding your supply of bitches to/ for my ting. Could you recommend somewhere alternative that I could find said bitches? I have tried Argos and a number of other high street stores and they were all most unhelpful and often acted as if I was causing offence. I have heard that a wonky numberplate attracts them in droves but I am not sure I want to try this...
This!
This works 110%, i am forever cleaning off run over bitchez as they are always hurling themselves infront of my car as i drive by. Use with caution.
PS me and Will will miss you in our 9n group :'(
I've got ta technix the same as the ones you fitted to yours, and as I've never fitted them I have no idea how the fronts go together. Is there any chance you could tell me how they go together, because they have a big aluminium cone on the top of them, does this get removed and replaced by the top mount and bearing?
She might be getting revived for UD secret tho
Close to what happened with me the cone that comes supplied goes onto of the Coilover then the top bearing and ruber top mount. Mine were fitted without the cone on and tbf my brother was a idiot for doing that as the spring inside width isn't even the same as the bearing. Hence the reason why he fitted them wrong. Left the bearing out and the cone so it was knocking its tits off...
Cheers for that, so the bearing and mount go on, then the cone goes on too followed by the nut? Its probably an easy mistake to make, not like you get any instructions with the kit so its not all straight forward, especially if you're not a mechanic (like me)
!!! :-p
D9B3ADC2-0E71-4AD2-A982-F684B7123ABC-332
Like the above order (on order of pic)
44B8841E-75A6-48B7-9F92-63A5721AAA5A-332
Hmm it's too tempting!!
Revival for the summer anybody?!?! I change my mind no end of times ha'
No more all reds - I sold them to Joe ah!
Started saving for the next car tho! Really badly want it but I think if this was low again I may fall in love again.. It's like having a Ex that you keep shaging, keep coming back for some more.
Logic is knowledge lads 👍💋
Peace out polo brothers!!
MetaphoricalSlagLAD.
Mans been blearing in his 1.2 standard "blowin exhaust" polo down broad street with a phat wackass micra and a Gti, fam got bear bitches licking my vw badge whilst plowin!! :)
Normal speaking now aha
Anybody fancy a sub? Amp? And headunit? The sub is that powerful it rocks the car side to side and sets off car alarms. Only 1800watt bro!!!!!
Aha propper ruber dingy wackass you know!!
Liam
Anybody want to see some objects dancing via the mighty sub?
Clicky
http://i827.photobucket.com/albums/zz192/c...zps496ac050.mp4
Aha shits and giggles
phat bass fam. Is that on the front seat with sub in the boot?! my rear view mirrors shake can I play?..
