Polo G40 1/4mile times.
Well just a quick question, whats the average 1/4 mile time of a standard g40?
Also what times have people achived with modified G's, maybe a good idea to list the mods or lack of.
Like this:
Polo GT
Engine mods: None
Estimated Power: 75bhp
Other mods: None
1/4mile ET: 16.4
I know g40s are not really made for the 1/4mile or 0-60 but its just a good gauge to show how well you cars performing.
  • Replies 32
  • Views 3.8k
Like this:
Polo GT
Engine mods: None
Other mods: None
1/4mile ET: 16.4
i think i have slip for mine that was 14.5 from a previous owner. only significant mods were the 65mm pulley and chip and R1 spec charger. will be aiming to get one done this year with myself as driver and some new mods
14.5 sounds quite fast for a G with just those mods to me. My Ibiza was running 15.5s consistantly and it was defanatly faster than my G40 (Pitstop toothed belts, Stage 4 charger and remap). It was also faster than the only G it went up against at the Pod.
I've seen a G40 on toothies, full-blend charger and chip do a 14.6s. It had good suspension and a driver with lots of practice - getting a G40 off the line quickly can be a bit of an art.
With a G-lader on, my best was 14.3s (no slicks), turbo was 13.6s (slicks). Yoof's done a 12.5s with turbo, slicks and nitrous.
You could get to the shop for a pint of milk so quick! Or even bread in your case haha
I personally got 14.9, this is with standard charger with 65mm pulley and jabba induction kit. Clearly like andy has said the start is the critical point as its so easy to light the wheels up.
This spec was rolling roaded at 135bhp at the flywheel
Edited by etches69
Polo GT
Engine mods: Lots
Actual Power: 223bhp (K03 + Gas)
Other mods: Lots (slicks, subframe)
1/4mile ET: 12.5 @ 110mph
Polo GT
Engine mods: Lots
:o
That is some mad acceleration there
my error, tracked it down, it pulled a 14.9
cheers for all the info guys.
I've got a fair bit of practice with launches, well with GT's anyhow, probably about 100runs or so, Dont think I've seen a standard GT go quicker than mine either 8-), that was with perfect launches and abusive gear changes.
All my other GT's even modified have struggled to reach below 17seconds. H266 DCK Red GT - If anyone knows where it is give me a shout as id love it for a daily runner again.
Alexm866: What power is you G running at a guess? 140-150bhp? cheers man.
Yoof: knew you would show up :lol: Cracking run there!
Edited by mattpolo5491
i doubt it was anymore than 150 but around that area, it had a read out of 170 in its history but I'm very dubious of that, probs optimistic rollers.
running near standard (abit more than 120 id guess) now for insurance savings and reliability (plus gives me something to look forward too when i crave more power), but have a quaife diff going on so would be curious to see the effects of traction vs power on the 1/4 time.
I'm planning on getting to the pod at some point this year when I've got the car fine tuned. should be good for early 14's, maybe quicker.....
I'll be interested to see how the Quaife-equipped G40s get up the strip at Pod. I've never done it in mine but I'd like to, just a little nervous about caning a driveshaft on the sticky tarmac. It's been fine on the road but I don't tend to launch it hard off the line.
Polo GT
Engine mods: Lots
Awsome :) :thumbsup:
There's less grip at the Pod than on the road unless you're running drag slicks and they've prep'd the surface. I've not broken a 'shaft yet, and neither has Yoof - though Hayesey's done one at the CV end by launching off the rev limiter.
Did that GT have modded suspension?
iirc it had a 40/40 cheapo kit on it :thumbsup:
Polo GT
Engine mods: Cam, 4 branch, golf AFM, chip, ported throttle body, full exhaust
Estimated Power: 103bhp
Other mods: Suspension = rear coilovers, No interior, 195/45/14 Falkens
1/4mile ET: 16.6
0-60 : 7.16
That was on a shit surface at GTi International 2 years ago, it was 30ish degrees that day too.
so what's the quickest known time in a G40?? I've never took mine up the strip!
well, it all depends on what you define to be a g40?
I thought that was easy to define! lol, a PY engine with a G40charger hanging on the front of it! if any of them two are changed its no longer a polog40 isit! any other mods are purely auxillarys.
The threads called G40 1/4 mile times, so if you dont have a supercharger your times dont count! its not a thread on times from a turbo'd 1.3!
Thats what i would call a g40 too, but theres a few that disagree, like if its a g40 shell then its still a g40 ect :roll:
But then its always good to compare :wink:
If it's a G40 shell with different running gear, then that's exactly what it is! A g40shell isn't anything special from a normal mk3! If only it was as developed as a g60shell compared to a mk2gti!
Yea good to compare but it's the supercharger power we all want to know!
Polo G40
Engine mods: 1341 Turbo
Estimated Power: 194bhp
Other mods: Gripper diff, PPP Stage 3 subframe..............and a few more
1/4mile ET: 13.7sec
Edited by Robin
