Breaking MK3 1l Flash red Coupe
just by any chance does this have the late spec rears (potential swap? worth a try)
also, how much for the wolsburg surround, i know its only one.
rear what, lights? not sure what the difference is but the car is 1994 so about as late as they come I don't need to swap as i don't need them as got mk2's
this is the car so you tell me:
£5 for the number plate surround if you want it, make me an offer on the lights if your interested and they are what you want
  • Replies 51
  • Views 2.4k
Sorry realised it does have the pair of numberplate surrounds I hadn't noticed the front one lol! So £10 for the pair if you want them
do you have the exhaust?
I only have the backbox spare sorry i need the rest
is the cap in good condition for the brake fluid bottle. mines broken to bits. thanks
What's the driver's side door card like Liz? Looks like it might be the same pattern as the ones on mine.
sorry i sold all the door cards, it had GT ones.
I'll have a look at the brake reservoir cap later, pretty sure its fine though
The roof gutters each side off the car if there in good condition :)
The shell is going this weekend but i still have loads of bits still up for grabs:
Tailgate - no rust or dents just a bit faded, with glass paint code LP3G
Front and rear lights
GT steering wheel
front speaker covers
Black Parcel shelf with 6x9 holes cut in it
parcel shelf supports
all door handles and trim bits
drivers side only interior adjustable wing mirror
starter motor 1994 car
alternator
1l engine - head gasket done head skimmed with new cam belt and water pump all done last year i need the SPI bits but will split the engine if anyone wants the head etc - no gearbox
rear bumber no scuffs or scratches
black carpet - hole in drivers side but won't notice if you put matts down
number 3 pool ball gear knob
1l ECU
if there is anything you can think of or want pictures of let me know.
thanks
I'm going to Stanford Hall so I can bring bits there if anyone wants me to put anything aside, but for larger bits I will need payment in advance
Do you have passengers door? And how much you want for plate surround?
This might well seem.... Bizarre, but how much for 8 of the wheel bolts?? Assuming that they're the standard ones :/ I can come take them off later on today if possible!
I've found out its not Tornado Red its Flash red paint code LP3G although that doesn't matter as I've only kept the tailgate if anyone wants that, its faded but not rusty
I've got all the wheel bolts loose you can have them for the cost of postage or if you want to come over at some point and get them, or pick them up from me at work in Whiteley you are welcome to them, just send me a pm
thanks
sorry the door was rusty and i sold the numberplate surrounds
rear axle mounts and handbrake bits, if you could just disconnet the cable at the lever and post everything (I'm converting my early mk2 so want it all) cheers.
Passenger side driveshaft with CVS and the exhaust backbox if they are good and posted please :)
sorry driveshafts have gone, and i don't have a spare backbox at the moment sorry
I took the handbrake lever and all the bits off so can post you the lot, all worked fine and in good order £30 posted?
don't have the rear axle mounts though as they went with it to the scrappy on Saturday sorry.
Do you possible have the full reservoior to master cylinder for sale? If so how much?
sorry it went to scrap with the car, i only took the cap off
You sent my ignition framing that i paid for :)
in the post tomorrow :-)
I've still got all the lights and other bits and bobs, including this bracket bit from behind the bumper if anyone wants it, and rear bumper all cheap! i can bring to Stanford Hall if anyone wants anything give me a shout!
Did you get the handbrake mounts off the rear axle? Don't need the lever btw. Thanks
front an rear bumper and door seals?
only got the rear bumper as above, sorry don't have the door seals.
I'm not going to post the bumper but you can have it for £5 if you want it
