Mk2 Coupe S Quad Headlight Front Grill
I have this spare grill off a Coupe S that's just sitting in the garage.
Is complete with VW badge, two small inner lights with bulbs and wiring and connectors for the extra lights. All you need to do is either run the high beam from your standard headlight or have as per late Coupe S, use them as auxillary lights so full beam is then the two main headlights and the inner lights. Makes full beam very bright.
I'd like £35 collected. I can look at postage and expect it to be around £10.
Collection from either Chelmsford, Braintree or Colchester, Essex.
  • Views 106
