Stainless steel rear bleed nipples to fit drum cylinders
I had a batch of these made up as i wanted a pair and it wasn't worth making 2.
They are exactly the same spec as OE, so will clear the cylinder allen head bolt/s.
I'm sure a lot of people are using rear disks, but for those that like things OE these are just the ticket.
I'll have to double check, but I think i have at least 6 pairs available.
Price is £10 pair plus postage.
Which may seem a lot, but will save you much aggro in future years when you come to bleed your rear drums only to find the bleed nipple is now round or snaps off on you.
Also not sure if anyone would be interested in S/S Banjo bolts for the charger feed and return oil lines? I had some of these made to OE spec as I was going to use Goodrige bolts until I noticed the oil hole was a lot smaller than the VW OE parts. There were two sizes iirc. I may get a further run of these if there is any interest.
  • Views 139
