mk1/2/3 rear disc conversion
so basically its a full rear disc conversion for all early polos excl handbrake cables/ adapters
included:
mk2 golf rear calipers
mk2 golf rear stub axles
new drilled rear discs with new bearings fitted only done 300 miles if that
new pads done same milage
stub axle bolts
caliper bolts
I want £150 collected
cost alot more than this and is all working perfectly
calipers were stripped and rebuilt using same parts as everything was fine.
they look great and are so much easier to service than drums and easy to fit.
  • Views 168
