what the f is this from
i found this random piece of trim in where my battery goes and I'm not sure what its from. i know its a vag part coz its got the markings on. jus dunno what it goes on to
i got a mk2 gt if that helps
  • Replies 11
  • Views 1.3k
I think its the cover for the hole where the carbon cannister is in the engine bay on a mk2f front left hand side of the engine bay
my thoughts exactly
but i dont have a mk2f this is confusing me
i dont think mk2 s had the cannister hence the cover
sweet cheers where is it ment to go then I'm asuming not in with my battery
i dont know where the canister is on a mk2f so wudnt know where is should be
yep bottom left corner of the engine bay. both my mk2's have one
front left hand side on just behind the lights on a mk2f
cheers chaps
I always wondered what that was but why would they make the hole there if they didn't put anything in it until 1990-1991?
They were planning well ahead. The nz engine was on the cards for years apparently. 85> cars even have an ecu bracket!
And inline fuel pump brackets. Converting a later mk2 to injection is a piece of piss cause every thing you need to bolt shit on to is already there for it
