New subframes available for MK2/3 polos
People actually pay that much for them? :shock:
Knocking up some thing like that in your shed with basic tools and experience then fair enough, but paying €400 for one? :lol:
Maybe its time ppp moved into the European market, Looks like theres some good money to be made
Edited by Mclovin
  • Replies 42
  • Views 4k
400euros? Bloody hell! I'm gonna get some metal in and make some up if they sell for that much.
daniel dont ask 400euro,s!! thats the price from stg... i dont think they sell manny...
you can make as manny as you want but are you gonna sell them also ;) (not overhere!)
i make most off those things by myself :)
that front bar , why not move it back to the rear edge of the arb mounts so it can be tucked up higher , that must hang right down on a mk2
Probably not judging by the reaction on here :lol:
if bin asking 350euro,s for a frame like mine.... i dont think it,s that much :)
you can make them as you like, there are allot of home made frames on the internet.
i also making rolcages for polo2 and 3 :)
The inner panel gets in the way at mounting height, so the crossbeam needs to be a good inch lower than the ARB to clear it on a MK2 if you're gonna go in front of it.
This highlights something i don't like about any of these subframes, and why i haven't made my own. They interfere with the crumple zone.
I don't want one of these things coming through the floor in the event of hitting something. Even slowly, low speed nudging the front against a solid object, that have bent the front valance, could be enough to push on the frame and bend the TCA mounts.
Until i research further on how to build a deformable frame like manufacturers do (yes i notice all these frames shown have a bend on each side between the front and back, but it's hardly Renaults sledge design), i'm leaving my crumple zone well alone, and using the passenger compartment to mount the suspension to.
yeah youve got a point there...a lighting nudge on the arb mount would knock it all back i spose
I disagree kinda.
these cars hardly have a crumple zone. well they do but its made of cheese.
if this subframe comes in enough to get to your feet, the engine is near enough going to be in your mouth.
the ones in this thread would go down and under the car anyway, no reason at all to come into the cabin. its the lowest part of the car.
You sure older VW's arnt just Designed to crumple?
:L
Precisely... Cheese :lol:
They're supposed to be made of cheese - so they crumple instead of the passenger compartment. They're a crush can, a shock absorber.
Once they've crushed most of the way, the cabin starts to bend. So the ratio is about right.
Considerably strengthen them with a subframe and how much are they gonna absorb before the passenger compartment becomes unstable? You don't know, you can only speculate. And you don't know what direction it'll fold in either, bearing in mind the TCA mounts are a hinge point - something the home-made one above addresses to a point by it's multi-point attachment to the brace as well.
Not that i'm entirely a critic. Look on You Tube and you'll find a clip of 5th Gear's crash test with an old type mini into the side of a massive Lexus LS400. It surprisingly showed the '50s design bend the Lexus into a banana, leaving the mini looking rather well, showing off doors that opened easily afterwards.
This thanks to it's subframe. And it wasn't originally designed to have one, subframes were added late in development due to fatigue in the suspension mounts.
However, the mini subframe is very different, the body behind it is going nowhere in the event of a head-on against a concrete wall.
This is not a good thing though, the shock rate is massive and passengers come off a lot worse than the car.
What you need is what modern cars have - a crumple zone, relatively made of cheese. And given the Polo's one is able to hold the ARB under the hardest emergency braking, it's not that bad.
not a great photo - but i knocked this up for less then £20 of steel off cuts from a metal suppliers
didnt put in the cross brace at the back at the time due to the gearbox mount - and in all honesty it really dont need it,
That gearbox mount is a bit of a requirement :lol:
Stops the amazing amount of power generated by the mk2f turning the engine upside-down. :lol:
NO i mean with out making a new one lol .. as when fitting the ppp subframes you have to replace it .. but ill try and use the standerd mount :) ...
front gearbox mount so the engine also starts to play its part in holding it all together and then it also bolts to the bottom of the chassis rails- the front beam is now the radiator mount/bar thing. thats why theres been mods because i later on fitted a 1W diesel radiator
skip to 2.00 for the crash
Basically if your gna get hit by any big yellow wagon chassis with no cab your gna die. Sweet, time to avoid the big yellow wagons!
Dont crash, simples
found this frame on polomagazin on a derby..
My car his crumplezone is gone,, i welded all the spotwelds and panels ;)
Edited by richard16vg40
