Serious Weight saving
Might sound stupid but replace all bolts that arent structural with cable ties?
  • Replies 105
  • Views 6.9k
any axcess wiring you can chop away? shorten looms etc? surely all the wire adds weight
looms all removed atm and i will be making full new ones to the minimal i need as in I'm getting rid of alot of wiring
race battery is a good idea, but remember on a FWD car, relocating more stuff into the boot isn't always the best idea.
I've got mine in the passenger footwell.
Il have a look at race batteries later an it's not going to be just fwd it will be 4wd
i know, i realise, i was merely making an example of weight distribution
If lightweight is your target why start off with 4wd? Huge mass and inertial loss penalty, as the components you have planned weren't designed with for a 1400 engine. Prop, diff(s) and shafts will all be bigger than you need.
If lightweight really was the goal, a motorcycle engine in the rear would be a far better direction, your average 1000cc bike engine is probably half the weight of a VW engine and box, and in a 450-500kg polo, adequate.
the reason i want to lose weight is to counteract all the roll cage and 4wd system if i wasnt putting that in i wouldnt bother saving weight as its light enough
4wd is gonna be pretty cool though, even if it ain't that fast!
Let it rust? Seems to make any car lighter
Custom driveshafts
Good shout! Some motorsport cars run hollow driveshafts! As the force is only put through the outer most extremity of its circumfrence it won't affect the strength... You could probably weld some up yourself using the original shaft ends, some tube, and a lathe :-D
Either that or make up some carbon shafts :shock:
Don't run air
Big turbo.
What's the car being used for?
What engine is going in?
http://www.dark-circuit.com/HOLD/Mod%20Guide/HOLESAW.JPG
oh - and I've done my research on this on the internet- if you fold the back seat flat it saves weight.
unfortunately the thread was removed where i got this fantastic tip from!
Could you get a carbon fibre bonnet for a mk2?
That would make a difference?
And as said, plastic windows, and remove wheel well :)
Gone the thread maybe, but the original post still lives on in the baron wastelands of the internet...
I agree with your point, but the car is a little quicker than the standard SXi and so I felt the SRi badges were appropriate. It only carries 1 person, Me. It has no extra weight in the car, all glove compartments, cubby holes and the boot is empty. The rear exhaust may or may not add power. It has only ever run on Optimax, I know you get more boost out if this fuel on bigger engined cars but every little helps. The tyres are always inflated to 38 PSI to give extra grip and less tyre slouch. Often I put the rear seats flat, this reduces weight. (Like why you crawl flat across a frozen pond so as not to break the ice). I regularly drive with around £10 of fuel, again weight saving, and often I use engine cleaner in the fuel load to remove debris from the fuel injectors. The car is always clean improving aerodynamic progress. I have timed the 0 - 60 at 9.3 seconds, and this shaves a couple of seconds off the standard time. Hope this answers your question.
The rear seat thing, It is rare that I fold them down, but it has to be said that when folded they remove a bit of weight. Vertical seats exert more downward force because the energy is focused on a smaller surface area. When horizontal, the weight is spread and so is less per Centimetre squared
Some sterling advice there that may help you out Pete, god bless corsa drivers :thumbsup:
Edited by Mclovin
Jesus, that fella missed out on a few science lessons didn't he
If that post about the Corsa isn't trolling, then god help him.
carbon fiber prop/drive shafts? they are very strong and will give a good weight saving on a 4wd as you will have 5 shafts to replace.
thats good advice, there is no point spending time and money reducing the weight of a car only to add 25kg of fuel you don't need.
the rest of the post is just shit
adds 10bhp too.
I thought the saying was that it lowered the centre of gravity if folding the rear seats down? Which it does I guess, technically. Haha!
Nah Chris it removes weight, see my post a little further up the page to see the post kiz was refering to. It's a post that went viral a few years back from a corsa forum
Lamb Tikka Bhuna - Swear I lost about 2 stone last time I had one!
