Serious Weight saving
Make it into a convertible, All ways works :p
  • Replies 105
  • Views 6.9k
carbon fiber prop/drive shafts? they are very strong and will give a good weight saving on a 4wd as you will have 5 shafts to replace.
Each one costing...5 times as much as the car is worth?
Front exit exhaust could save a couple of kilos.
You'll need the battery in the front, as a suitable cable for a rear mounted battery is weighty.
Steering wheels can be heavy. Wood rim sandwiched over ally tend to be lightest..
Fuck saving weight, just up the boost and get the same result haha
if they were that expensive you wouldn't see o.e manufacturers using them...
OE manufacturers have jigged and tooled up to make more than 1! so making custom one offs will be expensive.
i wish there was a smiley i could select which would show the face I'm pulling.
^^ I can imagine haha
Often I put the rear seats flat, this reduces weight. (Like why you crawl flat across a frozen pond so as not to break the ice).
:lol: :lol: :lol: :lol: :lol: :lol:
...trying to recall the last mass manufactured 4WD car I knew of that had carbon prop and drive shafts....or infact any car with those style of components that was the right side of £100k. This is real life not Gram Turismo, you can't win a few races and buy carbon drive train components for your 20 year old Polo.
webcam :lol: :lol: :lol: :lol:
Remove some screws and bolts holding things in like lights, one less screw would help... get rid of rear view mirror (not sure if this is allowed for a car as it is with a van)
Consider adding a single wiper if possible, in theory 1 motor should weight less than 2 and aero style blades.
Custom wood gear stick attachment and knob.
cut out spare wheel space and make it flat, with plastic screwed on
yahh you only need two mirrors by law :lol:
strip all the paint off
Might as well not wear any cloths ;) or shoes.
shave your hair and eyebrows off
:thumbsup:
Wear a hat to improve aerodynamics :p
Fill the tyres with helium
:thumbsup:
but that adds weight! if he shaves his head he can polish it to improve airflow
Made this yesterday, weighs nothing (almost)
542163_10151755380635276_525655275_24150
Rewiring the entire car and getting rid of a lot of the unnecessary stuff will save a LOT of weight!
that ^^
is seriously fooken cool.
The front wipers are powered by one motor, so there's not much weight to be saved here. However, I would agree with trying to remove the wiper and associated gubbinz. May save you a kg or so
that my friend sickest thing I've seen on here in years!
TOP JOB!
still has a ciggy lighter too :p ..
Props .. Looks the dogs dangly's
Is this in a track based car or ?
Yep. The rest of the interior before finishing wiring yesterday:
And best pic i have of the rest of the car next to my mates standard one:
It will be interesting to see what it weighs when done, although i suspect it'll be the same or more than standard with all that cage in, but more will be over the back so should be okay. I'm guessing somewhere between 700-750kg, maybe more, who knows.
I know its done for function over form, but that looks cool as fuck 8-)
