VIBE FLI 450 Watt Amp 2 Channel
Here we have a new, with box and manual VIBE FLI 450S amplifier! I have tested it to make sure it works fully! that was the only time it was taken out of the box, it has a blue led FLI logo that lights up on start up! This is amp is a 2 channel amp and is perfect for running components! can also be used to wire up a sub at 1 channel!!! my friend had a pioneer sub running of one of these amps and had awesome quality and sound! these retail at around £70-90 so grab a bargain!! The specs are:
FLI 450S-F1 Specifications :
Model Loaded 450
Type 2/1 channel
Class AB
4 ohm stereo 2 x 100 watts RMS
2 ohm stereo 2 x 115 watts RMS
4 ohm mono 1 x 225 watts RMS
2 ohm mono N/A
Max power 450 watts
Frequency response 20Hz - 20KHZ
SNR 90dB
THD 0.20%
Bass boost 0 - 12dB
HPF 45hz - 300Hz
LPF 45Hz - 300Hz
Input mode 2 channel
Subsonic filter N/A
Remote control Optional
Line out N/A
Phase switch N/A
LED voltage display N/A
Height 55mm
Width 285mm
Depth 250mm
Call me/text me on 07512728569 (can deliver at extra cost)
ONLY looking for £30! Collection from watford hertfordshire! thanks!!
  • Views 144
