Squeeling noise
My money is still on the drive shaft. How did you determine its coming exactly from the hub? The fact there's no mention of it changing tone as he goes round bends means it doesn't sound like bearings to me.
  • Replies 29
  • Views 3.2k
Right, I just took it too a mechanic and Basically he said 'he doesn't know what it is'. Wtf?! The noise disappears when its on the ramp or jacked up? which is confusing. The drive shaft nut was fine and all bearings are completely fine. Any suggestion guys? He only said could be possible that calliper needs replacing. But the guy seemed uncertain. HELP please...
I'm also running on JOM coilovers probably lowered around 40-50mm on the front. how would you know exactly if its the drive shaft? because the mechanic couldnt see anything wrong with it and also it doesnt make noise when its jacked up...wheels run free completely.
i had this problem with my 6n2 turned out to be wheel bearing ,drive flange and outer c.v
