6n 16v gearbox advice needed.
Hi peeps, well my gearbox has finally given up (whining in all gears) I want to re-con it myself but need to fit a replacement whilst i strip it. Will any 6n gearbox fit? I've done a search and there seems to be some confusion as the the afh has a bigger clutch? Some threads say to use the gearbox from the 1.6 glx? I'm not bothered about the ratios as it'll only be in there whilst i strip and re-build the existing one. Also are there any good guides on stripping the 085 box? Thanks :)
  • Views 355
