Mk2f Rear Suspension Mounts
My suspension isn't seating properly it has cut springs from previous owner. Is there ment to be some top mounts on the rear? The shock is cutting my struts apart there's nothing holding them down so I put a washer on to make sure they don't fall through while I'm driving? I could do with a full rear suspension set up with springs as low as possible
  • Views 487
