Damaged Seats
ok iv got a 1985 mk2 polo bready and ever since iv had it the front seats wont fold down to let people in the back of the car and I'm after some advise to fix them and how to take them apart :-D
  • Replies 9
  • Views 1.3k
  • thats fantastic thanks very much
  • caretakerplus
    caretakerplus
    I have successfully re-joined those cables using 'chocolate block' type electrical cable junction blocks. Regards.
They have a cable inside which can sometimes snap
whats the best way to get in and replace it
thnx for the help btw
Urrrm i think the last time i checked you had to pull back the seat cover,
Its got some tabs at the base which are like bent over to pull the material tight, if u bend them and then fold the cover back over itself you should be able to do it.
Its most likely only one side thats broke so if you cant be bothered to take your seat apart just pull the catches up manually, there in the back corners at the bottom, they hook the seat on to a stumpy sorta thing
nice one thanks il give that a try tonight :)
Hi
This thread I put on during the week might help
seat strip down
4th pic from bottom shows where the cable for the tilt mechanism is situated
Hi
seat strip down
thats fantastic thanks very much :D
Regards.
Regards.
same here, trim the frayed ends off the original, two bits of choc block with the plastic trimmed down and a short length of bicycle brake or gear cable to make up the gap, a bit of trial and error to get the adjustment perfect and thats lasted for years.
You simply need to bend back the three metal 'prongs' on the bottom, pull the seat cover down and away at the bottom so you can get your arm in there, then remove the plastics from the seat tilt so you can access the cables at the top. Remove the cable, repair, replace, adjust and put the seat back together.
I tend to remove the seat now since its a little bit easier for barely any effort.
Regards.
Brilliant thanks very much il give that a go :D
