Etches G40 Turbo
It is mate, just got to clean the gearbox up before it and the flywheel can get chucked on! The mrs isnt too happy about it being in the kitchen but hey ho hahah
  • Replies 201
  • Views 28.2k
  • After the final layer of Poorboys Natty wax strawberry mmmmmmmm strawberrrys
  • Quick little input, I've got a side full of nice bits for the G . Been mega busy with work and uni so its probably going to be May when she comes out. Should be a different motor by the time I've cr
  • Stainless one hasn't dude! Uni assignment ( 9000 words) handed in which leaves me free till november when I start up again! First couple of tasks are all structural, stitch both chassis legs in the
looking dead smart this!
Bloody love those cam covers, wish id have kept mine just encase i go 8v again.
Small update, waiting for the weather to clear then I can chuck the engine in,
pre paint before heat wrap
B78937E1-C782-4EA5-8182-FB5464DCE5FC-770
84EF639E-60DC-4D4E-A165-F495CA171BCD-770
Todays Update,
Gearbox was literally clogged full of muck and grease.
F2518B77-9E88-489D-9E18-A4FCA9761B1D-926
90% of a can of Gunk and 5 kettles of boiling water, then about 2 hours of drilling with wire wheels;
CD15FE89-C215-4440-89F3-6D31C5F4071C-926
Used the rest of the can to clean the engine bay , not great but good enough for me
4BAF35B9-002B-42DE-BDF9-2EFEA19252B1-926
Had a look at my old turbo, the shaft can be moved about 7-8 mm and there is oil in the boost outlet. Thanks to Paul for sorting me a newer one. Managed to clock the turbo using a rubber mallet and then swapped over the actuator and new studs etc.
7AE4E9A4-1A70-4951-928A-FA9D75BCF652-926
Needed to trial fit it to make sure it was clocked in the correct position;
C6CAB3BE-3648-4C00-988A-291FD11A232A-926
Wiped the gearbox with turps and prepped for paint
F20BB55B-5271-4B02-9B15-67FA09A1FCDA-926
Cleaned the turbo up with the wire wheel and turps too, still undecided wether to spray it yet
347ED2AD-FE45-4ADE-9E3A-0D1FFA0323DD-926
Gearbox and mount sprayed with 2 coats waiting for another tomorrow
4A629EEE-1781-4D7A-A9E1-6220124AF7AA-926G]
Edited by etches69
looking good dude! :)
Who needs build threads when you have Instagram haha :p good stuff mate, gearboxes take the piss to clean lol.
Instagram is much easier Nick, plus you've deleted your old thread off here havnt you? Can only see your progress on instagram!
deffo spray turbo!! looking good !
Put the turbo on the manifold , cleaned the dizzy which refuses to get any cleaner (N) and sorted out a new vw thermo housing and stat. Chucked the throttle body on too, just waiting for the boost switch to come back from a mate off Club G40 (calibrated to 6 psi) . Ordered a fair few bits off the eBay and stuff from ECP but will update with them when its all here
132795F1-59DA-452C-B8B1-BEF3804F2B58-587
Awesome , inspiring work ! .
Cheers man,
Todays updates;
Recent purchases, which also includes some BP8EVX NGK Plugs
A065CF27-F15C-4F4D-99B3-E2FBAB90DC05-117
Race fuel pump, Bosh Lambda, Spal Performance 11" Slimline fan, then service bits.
Had to make some brackets for the new fan, used the metal from the slam panel I had going spare.
435EEA4C-33D4-4488-9C5F-E1F03B4CCBCA-117
Also painted the radiator brace bar I got of Dan Knight a while back which will be going on
817CA39B-021D-4B2B-AE98-B2AC6522F5AB-117
Then heatwrapped my downpipe which was an absolute mission by myself, the cable ties supplied wern't long enough for 2.5" downpipe so I used wire intially then used jubilee clips to secure it well
E19BD29D-B2CE-48F7-A35D-9D0B15431CBB-117
73E8AD4A-1B61-4DF4-B8FB-E348F92884A0-117
e67b0cef-4f48-4536-b634-e48b4fba625c_zps
The dye from the wrap after I had soaked it went everywhere, good thing its water based tbh!
Todays had a fair 8 hours plus work,
B77C668A-ADB8-4D8B-B1C2-BAF23AE93B13-311
70BD65C1-A765-4E02-8145-BC1ABF0A297F-311
Flywheel with new bolts clutch then gearbox on in front of the motor,
Engine in
1BBDDD26-3D3E-40AA-9047-708678045F99-311
355DB6F4-CBC4-433E-A982-F556380B365D-311
Subframe and everything on underneath bar the downpipe, that and the turbo will get chucked on tomorrow
BC799C4D-3764-4B5A-B2AB-C016829CD2D8-311
looking good mate how long til its running you reckon
Not long Pete, need a few more bits!
After a trek in the peaks came home and fitted a small slot of work in;
8851391C-C96A-41B6-B9D7-FCB50F40099D-366
Turbo went on
B4C11D10-7F3D-40AD-96CE-64B85F07003E-366
0B38ABC7-0FAD-44DE-8798-1A916A453ABE-366
Then dropped her down , first time since oct . Just need a few more bits before shes running.
E6FD64E5-F9B4-427A-9741-70109C82F38B-366
3D9B6A22-3C79-4A85-8714-4F0F7E35F738-366
Looking great!
Todays updates,
New racing fuel pump and inline filter comparison
F362FE48-EF1D-4594-90BE-F90709ACA187-699
New Header tank
1086EDD5-2343-4107-A932-E12956E5C289-699
Sorted out the Rest of the boost piping and switch etc
78EB2780-711B-4F90-93A4-48655040FD03-699
New fuel stuff on
3538ACD4-36FD-4593-B0FE-88B1601F239A-699
Its ready run although I chucked some coolant in and it pissed out the thermo housing so I'm going to get a new oring tomorrow
Loooking amazing man!
Small update, went to start her up today and appears the starter motor I had spare is fooked. Another buy needed cos kays Polo had my G40 one!
Fitted a magnetic sump plug
E8039C06-67EE-4F3A-A254-DDEB3911951C-110
fair play for building this in the street.....
I'm a student currently dude, can't afford a unit. Would be an absolute luxury!
She's running now just got to sort this oil light malarky before I can put some miles on her!
Spotted your polo at Big Bang!! ! Makes me want mine on the road soo bad Iam in the red vento
Edited by scottycars
amazing the difference a new header tank makes.
looks fat bro!
Right, not updated this in a while as I've been so busy!
Got her running after changing the starter motor, sounded ok a little smoky but the oil pressure light came on.
Then this happend ;
AA137549-3690-429B-A66D-674A0B4E30F7-238
stripped the t-piece threads, ordered a VDO one to replace it from vw heritage.
Was shitting myself thinking everything had gone to pot as my oil pressure gauge read terrible figures. Nath managed to get a mechanical
pressure tester which had readings of 85psi when cold at 18psi warm, so that cheered me up.
So wen't to start her and drive away but I couldn't engage the clutch, assumed it was the self adjusting clutch so got a manually adjustable one.
Still couldn't engage the clutch, this was 10AM on thursday and I was due to leave for Big Bang on friday.
Decided that the only route for the problem was to take the gearbox off (90 mins later , subframe, drive shafts, exhaust engine mounts, gearbox and clutch plate) were off and I had put the friction plate on the wrong way wrong !!!
So Swapped the clutch plate round, changed the foobared release bearing too and chucked it all back together in 5 hours and after un seizing the rear brakes the G had its maiden voyage!
Only have the boost kept at 0.5 bar with the actuator for the run in period, managed 50 miles driving around before the trip down to big bang.
Also picked up this for an absolute bargin, just need to get 2 x 0.5mm injectors for it!
:-D
Nice pic from weekend with my mates abf nitrous mk1
