Etches G40 Turbo
I had a g40 for a few years over 10 years ago it cost me a fortune to eep on the road and that was back then.
  • Replies 201
  • Views 28.2k
  • After the final layer of Poorboys Natty wax strawberry mmmmmmmm strawberrrys
  • Quick little input, I've got a side full of nice bits for the G . Been mega busy with work and uni so its probably going to be May when she comes out. Should be a different motor by the time I've cr
  • Stainless one hasn't dude! Uni assignment ( 9000 words) handed in which leaves me free till november when I start up again! First couple of tasks are all structural, stitch both chassis legs in the
I have a rubber boot you can use for the boss mate
and did you get my message on instagram about the Wideband if you sell it I'm very interested ;)
Gimmie a Whatsapp about that boot dude, I'll let you know about the wideband. Jezza seems to think the stack ones arn't up to much :unknw:
New panels, going to be sorted out over the winter months for spring freshness next year.
Didn't realise how bright these are
bright like a christmas tree :o
Managed to scoop a facebook competition prize from here ;http://www.dirtyjoks.co.uk/
Used the Orchard Autocare Perfection product, smells awesome and produces a really good shine!
Paints all ready, just need to sort the trims the day before GTI Fest
Update;
Polo's having textured bumpers it's a nightmare to keep them looking properly black, Haslam mentioned this stuff so hopefully it lasts a while. Saying that I've only heard good things about it.
It's been a couple of months in the making but I've finally got all the pieces I needed to relocate the battery to the boot.
This is the kit car alloy battery tray which is finished in crackle black, seriously light weight and had 8 mounting points so it's fixed solid in the boot.
Used a dual 25mm connection block to join the bay wiring to the new 25mm wire I had to go the battery. Can see my brown battery tray (from the rust) which needs addressing at some point. I wrapped over the wire a few times with insulation tape to squeeze the wire into the hole I had drilled in the bulkhead, now its fixed solid so no rubbing hopefully.
I used a mega fuse holder with a 150amp fuse as this would blow before the wire would melt (200amp), bitch is that 5m of the cable just wasnt enough to route the wire round the side of the boot so at some point I'll have to extend it from the fuse terminal so it shouldn't be too messy. The battery tray came with a ratchet strap so it's held firmly down now, fingers crossed this solves a major rattle I had up front from the rusty battery tray. I did want the battery behind the passenger seat but the frames I'm using at the minute won't budge any further, at some point in the future I will fix the buckets properly and decide wether I want to move it further.
I like your tape player :p was it a tight fit?
Did you get your battery relocation as a kit? I've
Sceen the trays ect before, it's a lot of weight to be high up so your lowering your center of gravity
And putting a little weight into the light rear end :)
Nah I put the kit together myself from different suppliers, the plan was to place the battery behind the passenger seat. At the min the seat isn't fixed so its not ideal currently, when I've got my hands on the seats I want it will go there keeping the weight as low and as close to the COG as poss.
Ahh yes good idea, keep up the good work
Had a mission on tuesday through the peaks to Crewe 150 mile round trip in the G after the weekend going down to santa pod. Finally broke the 3k barrier since the rebuild. First issues appeared with the G on the way home. Speedo stopped working (dodgy cable) which had fluctuation in readings for a while so that was expected to go pop at some point, lost 1st and 2nd gear (I assumed it to be a loose gearbox mount bolt as having a subframe tends to work the bolt out) and one of the exhaust hangers snapped on the backbox. Sorted the mount issue the following day by putting a 10mm longer bolt through it, then went down to exhausts uk to sort my backbox (25 year garuntee)
They ended up doubling one mount and lowering the exhaust a bit to lose a bit of the rigidity which caused the failure. They also braced the backbox to strengthen it against flexing at the joint. More updates paydayish
  • 6 months later...
So ... exhale.
This hasnt been updated since October wtf! Shit loads of bits n bobs has happened since then and I've managed to keep some pics.
Due to the impending job/house move decided after a couple of trips buckets wern't a viable option, back to the standard in my opinion;
1aabec2f-cf9f-4255-b348-fe1763be231f_zps
With the need to get rid of shit for me moving away from Sheff, ended up doing a swap instead which went against the idea of selling stuff haha (cheers Martin)
435A3D1D-1F0F-40EE-A163-20C4D52FC089_zps
Briefly took a moment to look how far I'd come in 2 years of ownership
B5901B5B-6BC1-4D0F-8CA4-938534CEC7B9_zps
066D63A4-1155-476E-9035-33CAB56C64D7_zps
After a trial fit I decided that seeing as I had a sunroof, I couldnt have a full cage anyway without sorting that issue or sitting the seats on the actual floorpan. So the plan was to sort out a decent half cage out,
FB542C2B-D9BE-4205-A20B-6C9250A6F889_zps
Whilst this was happening began 40 hours of solid labour of moving and driving for 1200 miles in this beast
CAD84EE3-6728-4D56-925D-22F8BD4B4257_zps
So now I live in Cumbria and work here
43966D07-F7F5-4E5F-B2D8-88DE537EC5A2_zps
The G found its way to a new home, a little bit better than a really steep road where its had multiple gearbox and engine swaps
AB3F19DE-0B23-4B40-A73D-DC1ACA564876_zps
Old leads were looking manky on the inside so treated the G to a set of magnecores
36F7FA32-03F0-460B-9DD5-A8C6A9893172_zps
With the Cage ready to go in it went down the other afternoon, where a nightmare went down
416C6E14-51E9-4616-BC18-0706986B0422_zps
26C0E5DF-40E9-420E-8F53-4EA294D2AF20_zps
Hello fire and fuel lines! Good thing my fire extinguisher was to hand as my mate .Brad. put it out fairly quickly, just a bit of scorched paint and had to bridge the broken fuel lines which was very lucky really.
Turned out like this - Cheers .Brad. awesome skills man
DB53F872-42F0-4A74-AFA4-885E0F53D3D1_zps
Spotted this in Brads unit and had to have it, now got the bottle nicely in the boot!
51D4ED13-FA69-4857-8BE2-3E4CCB4B3D5F_zps
This is currently how I'm looking, already started to re route wiring to tidy it up and I've ordered some tesa tape to re cover them too. Got some plans for before Bujam and before Action too.
3A7931AE-5F58-4DF7-8B16-AA70B78CAAD0_zps
It's not running properly at the min, shitting itself at 10psi so got loads of things to pick through over the next coming weeks aswell as sorting some stuff for the MOT. Worst part is the fact the pedal box (inherently a weak point on Gs) has bent and is touching the steering column, got a spare which Brad is guna stitch for me to try and prevent future failures
6EB9F26C-31B1-44C2-926F-FAAE23B49FEE_zps
Till next time.
Had a fair old crack this weekend on the car, pedal box has been bent and getting worse for a while. Managed to source a used one, so had the ball ache of getting the old en off. This was the issue found with the old box;
13A9D432-C003-4958-819B-2B1C7E2B9D56_zps
189B3660-AFF4-42AD-B39F-089A74FABECC_zps
77290394-55D0-4D90-8090-80F4409F483F_zps
Cracked around the spot welds, was rubbing on the steering column too which wasn't pleasant.
Used one got stitch welded around the join on one side,
C2D2F3E4-B547-4611-9D62-1D7D9C116741_zps
Extra bracing and triangulation to stop it bending/ cracking again
E78E3266-0821-4E77-B591-1D72C979EBB6_zps
A02E0BD8-E415-4C5C-895C-322659C0CCB0_zps
Feels much better now so I can concentrate on the mods before bugjam. Its defo a job for winter sorting the full bias pedal box set up!
Cheers for the welding again Bradley!
Mot is coming up so it prompted a bit of work, well that and this.....
89ED0D5E-D7A8-438F-8D75-426967B3FD4E_zps
Happened just after a 220 mile trip so thank god i was 2 streets away from my house and I could drive in first gear there haha! Fingers crossed it was caused by the warping of the pedal box so a new cable should see the problem fixed till winter!
First job for the Mot was the handbrake/ braking system. Its been shite for a while so it needed a refurb. Driver side wasnt too bad.
C7884020-44BE-4A25-B439-66E6B1163030_zps
3087AEDA-A70E-4209-9FD4-7AD11CBBC65D_zps
7E5EDF50-9F44-4B58-A26B-8A2CC56D4617_zps
Mintex shoes and new handbrake cables. Came to the passenger side, wasnt so pretty...
3CD2FB0C-E1C0-4668-A72A-CA2D23F88024_zps
Clearly the cylinder is shot (hence a very spongey brake pedal and shite handbrake) . Ordered a 11mm brake pipe spanner to sort these as no where in Barrow sells it! Waiting for that to sort a new cylinder out and bleed the system.
After chucking the washer bottle in the boot, takes a while for the fluid to reach the jets. Got a tiguan 1 way valve to sort that issue
4C056767-50BB-4E52-85EE-07DEE94E9ED1_zps
Then a school boy mod, got a section of boot to delete this properly but sorted a bung for the time being, that and swap my rear sprayed vw badge for a black plastic one.
94CA0568-664E-47A5-A790-F020EBCF8FBB_zps
Update soon for the front brake assembly!
Old v new
237E10E8-41F7-4196-9123-DE4B4FC11D6B_zps
All together on the pass side
CA4F2D82-0A6D-4244-AA66-7E9A31F00C08_zps
Managed to get some more new parts , Corrado 22mm master cylinder
66876E96-BAE2-4765-8B4E-714A11568439_zps
Chucked the brake reservoir in the dish washer then assembled!
D03A12EB-3B58-45EA-AA75-1A4F19A3BC35_zps
Got some new toys (H)
AD32E360-914F-4CA6-BBE2-D51FFF0A172F_zps
Been messing about with the G again today.
Old
FAA8CEA6-2BE7-4308-B555-F6556585FB1D_zps
New
1B952E16-FABF-48DF-B8C6-F931036B902C_zps
Used an Ezi Bleed kit, which I might add is awesome. Looked like the fluid hadnt been changed in years
08A9E1EB-E499-45BC-8E0E-D856D4D81495_zps
Really really nasty!
Went over a significant amount of the loom today too, included lengthening a few bits to tidy it up out the way. Tesa tape is absolutely banging, looks the business
6C45A05B-F129-4644-AB60-FB0947DD3EF7_zps
Todays job was general tidying up, sorted the horn wiring. Found two blown fuses, stopped an oil leak at a sender then gave the old girl a full wash.
18A4A64F-336D-412F-BCC5-AD3317C151FD_zps
Cheers lads, MOT booked for monday. Started prodding around a few rusty holes and it got out of hand lol
1st spot
8C99B730-1C10-42CA-B212-E72415383BE2_zps
4A4C191D-3E1F-415E-B98D-F7643153D2EB_zps
E1A66151-68D4-43F0-B152-308E35459222_zps
Oops!
The rest..
C8375BF3-88E0-4A8D-99C0-AE33F4625A4D_zps
9798C014-E4F6-4C7D-B49B-CC84E178F70C_zps
419B0537-BF85-4350-9847-E0820BA50B0C_zps
Plenty of late nights required this week.. ie needs to be finished thursday night! (N)
Straight 5 hour stretch tnite!
Marked out danger zones
3CEE53D5-EF70-4DFB-A53A-D21E0C5D6C11_zps
All the shit cut out
D640E25F-82CA-4816-858B-84B6ABF57E93_zps
Metal cut
30FCE600-EA84-4C00-86F1-78122D52989E_zps
Managed to do two
6A1FED01-5E7B-4F55-89A0-DAA303893C21_zps
My appreciation for welders has gone up ten fold, I practised for about half an hour pre welding on the car and managed to find the setting I preferred. Only managed to blow a few holes but sorted em, not pretty but its solid as fuck.
Will get ground back tomorrow undersealed , high build then painted. Should manage to get to bed normal time hopefully!
Yeah , I've not enjoyed this job haha. What a ballache!!
Sorted the final two, the small one was an absolute bastard. Ran out of gas which made it difficult!!
981CD91A-3790-493C-BB12-5F1EE8B1D995_zps
All cleaned and undersealed,
EBD4903B-E04E-4A22-9789-F1F229467766_zps
Got the MOT monday , flew through with minors for a little bit of crumpled sill from jacking up and an oil drip.
F012CB70-DE32-4872-9934-F9FE5DAE080C_zps
On the way home to sheff lost all boost, got a massive blow from the turbo manifold-turbo section. Guna whip that off to check , fingers crossed its just the gasket! Polo show next week so best
Just spent the last half an hour to find this,
17BA46B5-AF0C-4C4C-A577-860A013ECC01_zps
11759541-776A-433A-B705-3ED3304A5E54_zps
E9B762A7-FA9D-4F8E-BF51-3C362045C5CC_zps
The old tubular - cast argument comes to mind lads!! Guna take it somewhere to get welded up prope
glad it wasn't too major of a thing to fix!
Does your down pipe have a flexi to the main system?
Yeah it does Nick, made sure of it when I had it all made. Downpipe has a bracket to the gearbox too for rigidity. Managed to get some of those higher shore engine mount bushes so hopefully that stops some of the rotation.
Managed to find some lad in Barrow to sort my manifold using a beast of a tig
3433B8C1-85F9-4B1F-9942-0C13EE670F22_zps
He did a really good job welding from both sides!
C4C7464A-E14E-4686-9E3C-C47831258C7A_zps
Been a really rushed week as I'm going to the polo show on friday, sorted the manifold
C93F2D8C-AD54-48B2-8484-448E23310437_zps
All back together, had a difficulty bolting the turbo to the manifold as the welds had given less room for nuts when fully tight.
4F8501EF-A0F3-4174-B89F-057CB759B5FC_zps
Happy I snapped these up last week, higher shore engine mount bushes and powder coated mounts
D8FB41CD-F354-4FB4-8380-E0F0142DDEBB_zps
Hopefully these should minimise the engine rocking.
Also managed to put the driver sill trim back on
E214BBF7-6365-4B9D-85FB-C7FE74187DC1_zps
Might get round to chucking those mounts on and give it a wash before friday
