Etches G40 Turbo
Got busy today. Changed all of the engine mounts for the poly ones and gave the bay a once over
4BFCC92F-B613-4EA7-8F0B-DC5F47CF0EF0_zps
Then managed to give the outside a quick wash
AA961F6A-62FA-470D-9FC0-1A5C8FA55A81_zps
Edited by etches69
  • Replies 201
  • Views 28.2k
  • After the final layer of Poorboys Natty wax strawberry mmmmmmmm strawberrrys
  • Quick little input, I've got a side full of nice bits for the G . Been mega busy with work and uni so its probably going to be May when she comes out. Should be a different motor by the time I've cr
  • Stainless one hasn't dude! Uni assignment ( 9000 words) handed in which leaves me free till november when I start up again! First couple of tasks are all structural, stitch both chassis legs in the
This is the start of a fairly heft update,
Did loads of little bits like putting a bigger washer bottle pump in as the mk1 golf one wasnt cutting the mustard. Then had a trip to the Polo Show which I might add really surprised me, had a right laugh!
Jordons abused daily
498F76B2-84EB-4319-BFC2-F1AFFF00CC60_zps
Max's bike carb'd g40
75296316-180D-43DB-B7F2-812651478A08_zps
0B60899A-9813-4C6E-BE9B-10D75AA63D4A_zps
It was so hot, paddling pool was needed
02AAA185-A204-42CA-8556-3950D3CAF4A8_zps
700 miles in a weekend which wasnt too bad! Got plenty of raggage.
Anyways needed some more feeds for the oil so I got another brass vdo tpiece, was a right farce fitting the sender in here
5B4E22E7-7DD0-4EF6-BA4F-FA53B56EE554_zps
Nearly completed my collection now
74897BF2-C57B-46BB-A040-86DA63080AE6_zps
then a school boy mod for the lads, chrome bonnet struts!
6CA67407-6463-476E-8D6F-3627D574E8B0_zps
Got loads of bits waiting to be done, need to make a few bits so will be an update tomorrow if some parts get delivered.
Edited by etches69
Bigger update on hold as parts havnt arrived!
Managed a little bit today, sorted the boot which will get sound deadened and then carpet over at some point.
C71A4230-4760-40D1-B62A-854DD2407064_zps
E606A41E-8AEF-4861-B013-E53CB3B785C8_zps
Needs another touch up coat but doesnt look half bad, got a bit of overspray but that can get sorted.
Got some powder coated wiper arms which really make a difference
6F1764D2-9EA4-4F54-AC3C-BA7BAA6DD12D_zps
Just waiting on parts now before fuelled and bugjam!
Nice work on the seals ! There always a bugger! Polos always seem to go on them holes, squirt some goo on the inside, there's access holes if you pull the edges of the carpet down. You can smash it in till it comes out the weep holes.
Really like you are rear brace also !
Nice work Tom!
Cheers lads, trying to keep up the pace with it
Boot now looking well tidy
72545FFE-B970-4753-9B52-BA60F07DBB48_zps
Door off
2CEB27F8-5C2C-4203-9253-632AC9B32917_zps
Transferring central locking motor and gubbins to new doors
4FD48B77-1DDF-4A6E-97BD-FA29F3A0CA29_zps
Door number 1 took an age, first time messing around with locks etc and I unhooked the inner handle to lock by accident. managed to sort it all out and chuck the door and a new wing mirror on. Door number two time came...
60D152FE-C4DE-49FE-8BC4-AD59370F772E_zps
This is supposed to be a new door lol, ground it all back, made a repair patch as this is where the inner swing handle is mount. Welded it and sprayed it up. Everything back together including new winder motor and another wing mirror plus the central locking stuff.
5DD2B6BA-35E4-41A6-B49E-DBCCB39F9077_zps
Both doors are now on this is the pass side, which is much less rusty just needs a minor fuss
CEA491B2-FD2F-4BFA-9512-FB16993414F2_zps
Managed a quick oil and filter swap before packing up, oil came out pretty mucky after 4.5k miles so I'm glad I changed it all.
Boot all packed for fuelled society this weekend!
5BEF2746-CB2F-4551-B12D-937DAB31A308_zps
Edited by etches69
looking really good now Tom! what rear brace is that?
I got it made Jordon,
New goodies arrived
47F38D8E-3FEF-4A4A-8F41-218DF5E8642B_zps
New to old comparison
0D92B426-DD84-42DD-97C5-47115B2B0B2A_zps
D29051C1-0527-44D4-8AD7-BE7B85C4C871_zps
Finally after 2 years fitting my radiator brace bar , comparison between the old/new
D3760498-8EE4-4170-9B09-2B3C69D80495_zps
All together
58918B2A-64F7-42C1-A0EB-B2BE74726B94_zps
4BE775E7-AE16-4606-ADC3-03C0F8D298FA_zps
Nice pipes, were they from the group buy a while back?
Cheers Jake, yeah off the group buy. I managed to pick them up off Taylor!
Wouldn't personally have the blue, but they look smart with the HTleads matching!
SFS also do a really good boost pipe clamp, if you ever suffer from them popping off.
Can you still get the radiator brace bars?
I dunno whether Dan has any left mate! I'd imagine not!
Minor update, been busy heading up to shows. First Bugjam....
222F3EC0-C094-4FCA-8357-62245C543E2A_zps
A173E070-9817-4117-A106-90AAB38D5350_zps
Cheers to Liam Holloway for those pics!
Then I went to G40 Rally through the peakdistrict too Tatton Park
Cheers for those pics James Morgan!
Tatton - bonnet lifters have broke already :(
499fb3e7-2f59-4eba-8dc9-0bb209f9c22f_zps
Came home with something I didnt expect.
CDDFEAD8-C306-4840-B75C-D1B9D52C4A50_zps
Ported polished, jabbsport bigger exhaust valves (BVH) which will be getting sorted by RES with the new guides and stems.
4C6986C1-C98F-4C01-AD3E-8F7A58240F7C_zps
219AC7DA-0508-4F98-8A8B-E0FC85C80FA9_zps
Went to clive at Autotronix to get my bigger injectors cleaned and tested
F47AEA5B-2BF9-4AA6-8105-5DE80D3A45E8_zps
20 quid for power runs and its only just outside dinnington!
Sorting some bits out for action, hopefully in time though!
Edited by etches69
Been busying around on this before action.
Stuck bonrath poly top mounts on the rear.
4CBF724C-1AB3-4EBE-B069-2414F60A4A88_zps
Throttle body off
8F75D9BA-F34F-48F3-90A3-0A32921CF171_zps
Injectors changed
B7B9DD13-8BA7-4188-8DA1-A2E14953B672_zps
Had a aquamist kit a while, just been collecting new bits including a .3 nozzle, new lines and I've got a filter and right angle on the way. Picked up some devils own meth too which was on offer. Just need to make a bracked for the tank and find a home for the pump and should be good.
E20565CD-70F0-431B-8790-0DB71592FDCE_zps
Got a new ecu with 1.5 bar map sensor in on the way aswell as a PPP chip to match.
Did a little bit today, still waiting on stuff being delivered but managed to get some done.
D3FEF932-643C-4980-A30C-2B67B3F07556_zps
Pump and boost switch fitted (waiting on right angle nozzle adaptors for the pump)
6762A590-1085-4492-B5E1-1EB321E75106_zps
Made a temporary mount for the bottle.
43ED71A2-7C30-4901-9951-5C775A63A239_zps
Need to crack on ready for thursday!
Tonight's activities, a good few hours went down. Including parts delivery of which 2/5 fit ! Bloody hell!
8FCB6750-19EE-494B-AE44-7B4BE06C3BD3_zps
Stripped the old loom, added a few bits and wrapped that shit up.
8D862648-E547-46FF-80DA-83274DF45ED9_zps
Tapped a thread in my boost pipe for the .3mm jet with right angle bend
36149F0A-855F-405D-860E-9E426EC44BE0_zps
Fitted the bottle which had to be altered to avoid the bonnet
51D58C15-BDBD-4C7A-8850-328745B45B53_zps
Everything is in order now
FB487FE6-09F7-4CDB-A07C-24320BFC264B_zps
02BE60FC-9BC9-4F04-813A-CAC5BDE9B59F_zps
I've cut it close to the wire, will have to put the chip in the ecu (it's due to be delivered) before setting off tomorrow!
  • 5 weeks later...
Right, lets rewind to thursday pre action 28th August. Drove down to sheffield with a massive air leak which was stripped threads on the inlet manifold, swapped it out for a g40 manifold and didnt leak. Was out testing the G at 22psi and had a boost creep which caused it to overboost at 7k rpm . Something went pop , reduced power and temps went crazy...
Last thing you needed at 2am day before a show!
Had a right laugh at Action but needed a recovery the 200 miles home, cheers AA
bbecbf57-e685-4f71-a44f-70e3b9de99c4_zps
Fast forward to now (I've been on holiday in between)
Head off,
15366801201_cf5d970126_b.jpgUntitled by t_etches69, on Flickr
15369962145_ce884689b2_b.jpg by t_etches69, on Flickr
3rd cylinder
15369960415_3276e53b2a_b.jpg by t_etches69, on Flickr
Head Gasket - Went in 3 places!
15366798291_0d72943974_b.jpg by t_etches69, on Flickr
Plugs -- ends seem to have burnt significantly shorter
15183261230_43f7714998_b.jpg by t_etches69, on Flickr
Edited by etches69
  • 3 months later...
any update dude?
Ouch!
Quick little input,
I've got a side full of nice bits for the G . Been mega busy with work and uni so its probably going to be May when she comes out. Should be a different motor by the time I've cracked on. Just got the annoying task of replacing the battery tray and strengthening the bulkhead where the pedal box attaches!!
  • 3 months later...
Jesus - Just got the 120 Day warning for posting in here lol! Need to sort my act out.
Been very busy with work amd uni recently so not had much spare time for the G.
Current state it's in , no engine in , no front brakes , no front end ..... lol!
Managed to source some Calibra front calipers, goodridge hoses , grooved golf gti 256 discs and some what look like Yellow Stuff pads, so they will be on by the end of the week hopefully (cheers Martinn!). I've got the full set of Mk4 golf rear calipers to sort too but need a handbrake cable piece first, hopefully manage to get this sorted before it comes back onto the road.
Engine wise , the new BVH has been to Sheffield Engine Services for a skim, new stems and guides, 3 angle cut seats and a pressure test. Also got a new set of tappets for it too when i fetch it so should be nice.
Gearbox, it's out of the car waiting to be pulled apart. Got the diff ready to go in aswell as some other seals which I've collected over the past few months. Also got a custom driveshaft for the drivers side but I need a rattle gun to get the hub nut off or a scaff bar!
The K03s turbo I had sourced turned out to have a crack in the exhaust housing, so thats been off to Midland Turbos for a rebuild, new housing bearings and oil seals. Should boost solid now (fingers crossed).
I've been putting off doing the battery tray for too long now, probably the source of many snapped pedal boxes, so thats the first thing on the list after she's back on wheels. Pics to follow.
Need to get my arse in gear to see it ready for bugjam!
Calibra Calipers , Brembo 256 grooved vented discs, Hel braided lines and EBC yellow stuff pads.
Just sorted the clips out on the calipers and shes back on wheels. Engines been pulled and gearbox off ready to be dismatled!
Edited by etches69
Was the calliper swap just a straight bolt on?
Yeahman, just need to get hold of the right ones!
Bit of progress
Engine bay looking a sorry state, going to give it a pressure wash and stitch the chassis legs aswell as doing the Yoofington brace mod.
Engine nicely on the stand ready for a fuss over , collecting the head this week. Got a little problem with the pukka oil drain , it bloody leaks! Need to get another one made up, prob will be a few quid :( .
Thought the 256 brakes would fill the wheels a little bit more than they do! Everything needs a clean up though, check that dust out!
Special Delivery! 8)
Rebuilt K03s new exhaust housing every nut/bolt and seal changed. Even threw in a new actuator which I dont need. Should look nice with a fresh head and cast manifold though. Keep up the motivation!!
