Smiths 3 Spokes 15x7 and E30 BMW BBS 15x7 both 4x100
First up are my 3 spokes. They are 15x7 with an et of 38. The center bore is a little larger than vws 57.1 so I assume they are renault fitment of 60.1 but you cannot tell once the bolts are all done up. However for a couple of pounds you could get spigots off ebay. They all have slight curbing but nothing a quick refurb couldn't sort out. All 4 have center caps, all in almost identical condition and all 4 got new 195/50 rubber put on them a couple of months ago and still have about 8mm tread left. I love these wheels but I get bored quick so fancy a change. I will probably regret this decision to sell but if you buy and regret it then at least you know I will probably buy them back. I will also get some better pictures soon. I am after £200 for these and I am already making a loss which is killing me slightly for something I love but I just want something different for my car.
Secondly I have some BMW E30 BBS Wheels. These too are 15x7 but with an et of 24 and a centre bore of 57.1 so will go straight onto any older vw. They are unfortunately missing the center caps but you can pick these up on ebay dirt cheap. My plan was to refurbish these and sell them on to make a profit but the lazy side of me cannot be bothered. They have all been badly sprayed black by the previous owner because apparently the original silver wasn't in good condition. I was just going to get the shot blasted then polish them up. They have 2 almost new 185/55 and 2 good but not great 195/50s on them. The 195s have about 4-5mm tread but one of them has camber wear on the outside down to about the 2mm mark. The tyre with camber wear also has a slow puncture but seeing as that is the only tyre that will need replacing in the next 10000 miles or so I figured its not a huge problem. I am only after what I payed for them which was £35 a wheel so £140. Once again, I will take some better pictures soon.
I will happily swap one or both sets of wheels for the right set of 15 or 16 inch wheels. Although they must be 4x100 or come with adapters. I will also sell both sets for £300 if someone wants them both.
  • Views 286
