ICE ICE POLO (ROBolop Design)
Sick!
Loving this.
  • Replies 43
  • Views 5k
Check the beemer on the last page I linked Harris! It's actually beautsiful.
I let someone make me a set of alu little busses, to go in between the amp and the EQ.
I'm planning of polishing these, so they shine like a mirror. Like that I'll get a nice contrast with the matt alu plate on the bottom.
The 4 who are a bit longer, holds everything that's on the amplifier, in place.
This will be the coverplate which will rest on the glass.
I made this one in 8mm thick MDF wood.
Off-course I made the 2 holes as big as possible, so you can see as much as possible of the install.
Because the middle of the coverplate is quite wide, I was afraid that I'd loose the effect to see from the front, to the back. But it's really ok, it's still looks fine.
Off-course I'm going to add some lighting in there too.
Here are a couple of things I picked up from the motorhos in Essen (DE)...
Everything I made for in the back of this Polo thus far, is removed from the trunk now. So I can give the trunk a good clean now.
sad-animated-animation-boy-smiley-emotic
The meaning now is to rebuild everything the install, outside of the trunk. But there’s a lot of work to be done first.
Some of the iron, aluminium I used, will be sanded off, and sprayed black.
The wooden box, which holds all of the components, will be glued together. The aluminium on the bottom will be glued tight with TEC7.
I was planning on making a carbon plate for it, but where I’m working now, it’s too moist, and I’m afraid it won’t be perfect…So I’ll have to come up with something else.
I also need to mill some other sloths in the bottom of the box, where the cables are.
These sloths go towards the sides, but if I look at it now, I just haven’t got space to place my cables there. Pretty stupid of me, I should have known.
Everything is ready to be covered in skai-leather, but I just can’t. Because it’s a daily car, we’ll have to use the trunk to place all our purchases in.
This means, when I buy some wood (or whatever), I have to put it there. It’s not possible to always put a blanket in there, being scared of scratchin’ it a little.
The best thing I can do is to cover it in to find the same piece of cloth the trunk is made of, and cover it in that.
Offcourse, that will look like SHIIIIIIIIIIIIIIT, but then again, maybe I should have left it like it was.
Sometimes women are right…SOMETIMES I said
I’ll sleep another night on it, before I open a bottle of glue.
www_animated-animation_de_smiley_3d_gifs
In despite of the cold weather, I went and buy some things I needed to finish the trunk of the Polo.
I also found almost the same fabric as the original one from VW (90% the same).
This was (at least for me) the best I could find. I know that it would have been much prettier when I would have covered it in leather, or alcantara, but I just couldn’t. This is a daily car, and the trunk has to be used.
I also bought some RCA cables from Dietz
Fuse-holder for in the front.
This self-adhesive (hard) mousse I’ll tape on the aluminium that comes on top of the install.
The aim is to have a good closure of the subbox.
On the cover of the amp, I’ll also stick this, so it can’t vibrate.
This self-adhesive 2mm rubber will get in between the rings of the speakers, and the aluminium.
Also to prevent vibration.
De O-ringen heb ik ook allemaal voor de afwerking van bepaalde dingen.
I also got the O-ring for the finishing touch.
As for the material, I’ve got everything to finish the trunk.
The biggest problem now it the cold weather. I went over there to take some pictures, and check a few things, but after a few mintues, I was almost completely frozen.
So I’ll have to wait for better temperatures to continue this project
I’m back in business! The goal now is to complete the entire sub-box.
First off all, I sanded the aluminum parts, in which the cables run through, firmly, because I was going to polish them.
I did the solid bar first, because I would take longer than the rest.
First I sanded it with the machine, this with a 240.
After that, with a wet 600, then 800 – 1200, and I stopped with a 2000. When I completed all of these steps, it was 2 hours later.
To do this in a safe way, I screwed the ruler on a piece of wood. By doing this you exclude the possibility to burn your hands when holding the wood, and it’s almost impossible that your piece hits the brush.
You can also see that I taped the plank with tape. I do this always so my brush isn’t full with wood splinters, and so you can’t make any scratches.
As for the little parts, I needed to come up with something.
And I found a simple way to fix this.
The piece on the right needed polishing, and on the left you can see how I screwed it.
Off course I also needed to go through all the sanding steps, but this went pretty easy.
I placed this in my drill machine, and let it spin.
So I just had to place the sanding paper against it, and keep it wet.
On the right you can see the sanded piece.
Then this had to get polished too, so I clammed a pliers on it.
So you can hold the little piece against the brush in a safe way.
On the left the result
This was everything that needed to get polished for the subbox.
For those who want to polish something, be carefull with this! And don’t use a big brush.
If you have a descent motor (about 4hp), with a big brush, you have a fat chance that the piece will bite the brush pretty hard, and you’ll feel a big slap in your arms
I also added some LED lights in the box.
I also mounted the self-adhesive mousse, so the box will be tightly closed.
CAN'T WAIT TO SEE THE FINISHED PRODUCT!
Man, I followed the BMW from day one , you're awesome ! I'm putting my polo on a truck and sending it to you along with a blank cheque ! Okay ? Deal!
The first piece of the polo-ice, is ready, the sub box. yihaa
About the connections, I’m very pleased I’ve done it like this...
I thought everything will go much smoother by making this so, but you can forget it.
I had a huge amount of work trying to mount it all nicely, and getting it all aligned.
The O-rings are the finishing touch in my opinion.
The cables were the things I had the most amount of work on. These need to be placed in the same line, and then again, have the same curve. To do this I made a couple of cardboard molds and checked for over 500 times if everything was correct.
This was something people would have a comment on like “cool, but the cables are not all the same, and offcourse, I want to prevent that to happen in any way
I spread the 4 connections over 3 days. I mean, when you checked something about 300, you make yourself crazy, and you don't see little errors anymore.
The day after, you immediately see something appear, and the day after that you can make it for 100% perfect.
You can judge yourself, but the picture doesn't give a perfect image, cause it wasn't possible with my camera to put they all in one row.
When you look at the connection in the front, it seems like this is morde round than the other one, but that's not true.
I'm pleased how it looks now, but I've put a lot of work in this little box.
I added some lights too, and it sure looks nice (if I may say so myself), but I'm going to wait some more before posting this
The subs are hooked on, and the next thing I'm going to do is to mount the box in the polo.
The amplifier is going to be hooked on when it's mounted in the car. It will be much easier to work on.
Up to the next..
Awesome skills!
Look forward to seeing it finished.
I’ve taken some pictures of the subbox with the lights on. This wasn’t that simple. Once it’s all finished, I’ll ask a friend of mine, who has some professional material, to do a shoot for me.
He took shots from the interior-lighting from the bimmer last year, and that was BAM!
As you can see I chose red. The interior lighting is also red and white, but white sounded a bit “boring” for me.
The only thing I can’t stand, is the reflection of the LED’s in the polished bar.
I had this in the bimmer too, that’s why I’m going to experiment with this problem…
If I can trust the weather-man here in Belgium, it’s going to get pretty cold again…so the thing is that I’ll have the put the works on pause again
I was sick for a couple of weeks, but now I’m cured, and ready for take-off!
At least, I thought I was…till I saw there was a crack in the glass.
After some swearing I screwed it loose.
I thought “let’s cut it loose from the aluminium, but damn, was that disappointing”
The easiest thing to do was to crush it all with a hammer, and then cut the Tec7 through with a nice.
A really sh*tty job
Of course I had to find the cause of this problem, and I found it immediately. The alu framework, where the glass rests upon, isn’t 100% equal, so it’s normal that it broke.
Now, I rather have this going bad now, then when it’s all finished.
The glass is ordered, and tomorrow I’m going to do it all over again.
sh*t happens
I’ve started again! I screwed a 2 mm thick aluminium plate onto the bottom of the box. So you can’t see anything of the cables anymore, and that’s much better.
If everything goes well, I’m going to mount it in the Polo tomorrow.
Tomorrow has been and gone! Showw!
I’ve started covering the parts for in the trunk.
The alu part you see in the hole, is the plate I made so the little door will not be able to shift backwards.
Here the little door when it was freshly sawn, just need to cover it. The plate harnesses itself in the hole, and I’ll tell you how to take it out, once it’s covered in clothing.
This is the left side
I covered this last night, and where I’m working now, I haven’t got so much ligt. So when I looked at my work outside today, I… @$esd)!
Here you can see why.
The colour of the lower part is a bit more dark , and I didn’t see that. I bought 2 rolls of fabric, and apparently it wasn’t the same color.
So I’ll have to start again.
Every disadvantage has an advantage … Now I’m going to know how strong the glue is I’ve used
F-ckin’ hell!
You my friend are a fucking LEGEND haha, I have been hunting high and low for ideas on how I could do a custom boot build for my gfs polo 6r that could still fit the buggy in and this will be perfect thanks for the step by step guide :D
GO 4 IT
Edited by robolop
GO 4 IT
Wouldn't be so confident, Will take some much time!!
Because we bought some winter-tires a couple of months ago, I also needed a set of alu rims to get some summer-tires on.
Original there’s a 15 inch on there, and off course I wanted to go 17 or 18inch… But as I said before, this car is for daily use, and my wife would have chopped my head off if I went bigger in size.
So I let here make a decision, and personally, I think she’s done a good job.
These are ordered, so I’m waiting delivery in a couple of days.
T2eC16ZHJGE9nm3q82eBQ7WVLMvg60_84_zpsd09
The ICE-project is on hold for the moment, it’s just too damn cold in my garage.
