mk2 polo bulkhead divider/firewall/scuttle removal guide?
EXUSE TO WHORE AWESUMNESS :lol:
ignore4 the third runner, its ever so slightly shorter... ill sort it when i weld it up tomorrow :)
  • Replies 51
  • Views 7.2k
you could change the bulkhead to accommodate the carbs, get a photoshop done and look
Mani does look good. First one I've seen that doesn't have round tube and ported flange!
I see your point about the fully smooth look Eric, which is why I keep going back to the thought of doing mine. But then I think of how bad it might go! Also your sacrificing a bit of chassis rigidity. Although it's probably not too much to worry about. But then to me the fully smooth look means being rid of everything from the bay, including fuses and everything I have mentioned above.
Why have you made your manifold so long out of interest? You may yet find it too long
but simon i have one of those oober cool strutbraces, you know the ali ones that turn my polo into a racecar haha :lol:
just thought id give it a go tbh! if it doesent perform well i can always shorten it. i always end up with a really short manifold on my engines, wanted to see what difference it would make as noone has experimented with different lengths before
Well that brace may do something for you now!
It's going to be difficult to workout whether the manifold is givining you gains without trying a few
Well i suppose the only way to find out is to try it! Surely longer would be better for the air/fuel to mix ect? Plus it looks awesome
Of course, but ideally you want several identical runners (bar the lenght) to try out. Longer runners should give you better low down torque, but once past peak, you may find the engine struggling.
The luxury with long runners is that if you find this is the case, you can always chop a bit off and see how that helps. Easier than but welding a longer piece of tube on if you find its too short
This is my exact thinking ^ :)
We're not all into this smooth empty engine bay fashion, much as it gives you a nice shelf to put your beer and sandwiches whilst polishing whatever's left in there. When I look in an engine bay I wanna see all the stuff that's supposed to be there, not wonder where or why it's been hidden.
Removing the panel opens up the bay and makes it more spacious, practical to work with, and better looking from my engineering perspective.
I'm having serious thoughts of doing it myself, but instead of removing rigidity-assisting strips of spot welded panel and trimming right back to the turrets, I'm likely to just cut away what needs removing, fitting an edge trim over whatever remains.
Eric I was thinking,
What if you effectively cut it out, like leaving a 1cm lip all the way round, then put some edging strip stuff on it to make it look presentable?
Mate....
Thats a fucking plan!!! Sounds like a great idea! I could use the raintray strip
Bit of a guess as I havnt looked in much detail what the crack is, sure it wouldn't be that simple but maybe worth a bash.
tbh though, it probably would be that simple. haha. just scribe a straight line across it and go easy with a cutting disk.
not that it looks like I'm doing it yet. NEED A CLUTCH AND FLY!!!
I said to you why don't you just cut the main section out and put some edging strip around the sharp edges?! :lol:
Thats the best thing to do if your not gonna smooth off where you've cut it out.
You saw it in my post first..
I have thought of a problem. I still have a header tank... gonna have to either leave that small section in or rivet it onto somewhere
Get rid of it?
Need a topfill rad for that though. Which is gonna have to wait
Go get a cbr airbox man .. can use that and have a nice cold feed too .. Tbf mine wasnt far off beeing able to fit one
I have visions of a poorly cut out square just for the carbs to sit in.
Won't they be spraying fuel at your heater without the bulkhead
Probably yeah.
cold night, boots it... someone sparking a fag in passanger seat.. Flame throwerrrrrr!!!! lol
Why would it? I'm gonna run ducting from the heater so it gets a fresh air feed.
Also no smoking in my car
Use tin snips or simular, dont go anywhere near it with a angle grinder, it just makes a mess.
id use a jigsaw personally.
