6n2 wing mirrors
Sorry if this has been asked before, I've had a look and cant find an answer . . .
To remove the plastic casing from the wing mirror (The top part/same colour as car) do you have to unscrew the screw on the underside or does it just pop off with force?
Thanks
  • Views 1.3k
  • Rear view mirror 10.99 > Removing mirror housing ‒ Fold rear view mirror forwards to ease dismantling/assembly procedure. ‒ → Position mirror glass -2- vertical (otherwise mirror housing ca
You need to put a thin screwdriver in hole and push metal clip towards front of car
I took glass out first
‒ → Position mirror glass -2- vertical (otherwise mirror housing can catch on mirror glass when pulling off).
‒ Insert screwdriver -5- through assembly hole of mirror carrier up to clip -4-.
‒ Press screwdriver -5- in direction of arrow (this will cause the clip -4- to release the mirror housing).
‒ → Pull mirror housing -1- off mirror carrier -3- upwards.
Ahh brilliant! Thanks guys!
