6n2 polo AUC 1.0 engine
I have a polo 6n2 1.0l mpi engine (AUC)
before it was taken out it it had the top end completly re built that cost around £400
I.e.
new rocker cover gasket
head gasket
8!!! new valves
head skim and timing belt along with the norm aux bolts you would use too.
did about 1000 if that before it was removed so sweet as running.
Does not come with gearbox shown or drive shafts
had done 101k but with rebuild it felt like a 20k engine
However comes with:
alternator
inlet mani
injectors
water pump
starter motor
and ECU
No loom tho
Pics
Injectors
NEW belt
engine code on cover
New valves
Top with alternator
and finally... (remember DOES NOT COME WITH BOX) :D
now
I'm going to say £200 OVNO and if your local and it sells for the right price if you need help fitting it.. well just ask :)
PM please
  • Views 245
