How to Swap the Glovebox Lock on MK5 6n2
Iv changed my interior from grey to black so i thought it would be nice to have the lock working too so i had a go, anyway heres how to do it.
Theres two small holes in the glovebox lid, to get the mechanism out you need to push two pieces of plastic inwards ( see pic 2 + 3 ) you may need to put a screwdriver in the hatch to prise it downwards at the same time, once it goes down each side about a cm you can pull it out. To get it out fully (it will be half stuck) you need to pull the handle upwards ( as in your opening the glovebox ).
You will be faced with this, prise off the cap by levering a screwdriver under the runners (gently) if one doesnt want to come, try the other first, once it comes loose you need to press the catch down to get it out
Then you need to get the lock out. I would STRONGLY advise putting the key in first to stop all the tiny springs and stuff falling out, mainly so if you have lost a few springs from your lock (like i did) you can rob them. Anyway, there are 4 small tabs holding it in, prise them off just enough to get it out.
Do this for the other lock (to get your barrel, or remove the other ready for fitting).
Once you have your barrel you want to fit, it should look like this, notice how all the tabs are smooth. If you dropped yours out try swapping them around to get the right way.... theres only 9 ways :) Note that it wont work if all of the springs arnt in.
With the key still in put it back into the flap as shown.
Push the tabs back to hold it in place
I would advise putting a drop of glue on them to strengthen them, i used a form of Araldite. DO NOT put it all the way around as the whole barrel spins.
When its gone off hold the catch down at the top to bring out the mechanism inside and fit it back in. You will see a notch where it needs to go.
Test it out. Lock it, unlock, try the mechanism. Then pop it back in. The tabs that you pushed in earlier may need to be prised outwards a little to help it grab it like mine did (one side pulled out when you pulled the flap down)
Hope it helps.
Guide only, not perfect, but better than nothing
  • Views 4.3k
