Polo 1 litre Turbo, for sale AGAIN
k ill come back in a month .. be 1750 ..
Saying that,they cant be that rare the paseo's seen 2 last night :S lol
  • Replies 496
  • Views 26.2k
And the blow is on the manifold before the turbo so it isn't boosting fully
That's understandable tbh, after all I guess it wouldn't take much of a blow to loose most of its 4psi
Funny how its an EXHAUST leak so how would it loose boost pressure :/ it's a separate circuit so it won't loose any boost pressure just take a tad longer to spool up :)
Am I wrong .?
No reply guy? :lol:
Am I wrong .?
Am I wrong .?
No reply guy? :lol:
It maybe a separate circuit but both circuits work in unison, without exhaust gases you have no boost pressure, the more gases you lose before the hot side, the less boost pressure you will get from the cold side. A wastegate is designed to limit boost pressure by allowing the exhaust gases to bypass the turbine which is what would happen with a blow before the turbo. So yes, you are wrong
I thought you designed engines? This is pretty basic stuff
I know the blow would have to be pretty big to see no boost pressure at all, but I wasn't going to let that get in the way of my joke :thumbsup:
Edited by Mclovin
He’s not 100% wrong (for his setup), although given a lack of an argument as to why I'm assuming he doesn't understand.
As it’s such low boost the wastegate has to be open a large amount anyway, so a good percentage of the exhaust gas mass flow isn’t actually spinning the turbine, i.e. the wastegate has headroom.
Introduce an exhaust leak, and the wastegate will close to achieve desired boost.
Now, 2 things:
1) This is less efficient and although peak boost may not be lower, transient response will be worse
2) It’s less efficient
In a turbo setup when the wastegate is closed to achieve boost for a good portion of the rpm range (K03, 22psi+ for example) this will make a difference to peak boost, as the wastegate is normally fully closed to achieve this with 100% mass flow over the turbine, i.e. it has no more to give, so as soon as some of the exhaust mass flow is lost, boost pressure drops.
Been through the entire thread.
Fuming there isn't a video up after all that..
Sort it out.
you dont seem to get that even with the blow it is still reaching the external wastegates setpoint :)
i already stated that it would take longer to spool...
literally one engine bay pic would satisfy me
and if i came on here raving about turboing a 1L thats the first thing id post :lol:
Edited by Josh16v
Now, 2 things:
if the turbo was being maxed out then you'd be right but the turbo isn't its still reaching the limit of the external wastegate and then its bypassing the turbo after 4psi because the spring is set to fully open at 4-5psi, so it will take longer to spool or transient response will be decressed what ever but it will still hit the boost limit after more lag than if it wasnt blowing.
i do no what i am on about either I'm not explaining my self well enough or your reading it wrong but whatever.
been done earlier in the posts.
Now, 2 things:
I think if anyone knows turbos its yoof :lol:
Now, 2 things:
Did you read what Yoof wrote properly? He's actually agreeing with you. Maybe if he'd written it in ill-punctuated text speak you'd have understood.
Still waiting on a reply as to how you were going to remap the existing ECU for boost by the way...
Now, 2 things:
Read my post properly, it articulates the same point you're trying to make, just I can spell, and am an actual engine development engineer, not an Internet one.
:lol:
Now, 2 things:
Love It!
powneddddddd - something like the way his turbo setup would pown yours i think :lol:
This thread is awesome! I'm up your way saterday, pm me your address and ill get the desired pics/vids everyone needs, I'll take you out in my 16vG60 if you take me for a spin too!
Edited by SuperMario
looking forward to the video
x2... LOL
No excuses now :-D
This thread is missing GIF responses that I've become so fond of on club polo
Here's a 5th gear pull of Yoof's car:
http://youtu.be/vdr8VUh3gu8
I'm sure he'd oblige with a 4th gear pull too, were there not a massive hole in the size of the gearbox where 3rd escaped.
3rds overrated.
If only yoof had worked for JCB as a minor,would have known he could cellotape a turbo to a 1L and seen 160 with ease
