Polo 1 litre Turbo, for sale AGAIN
A??
  • Replies 496
  • Views 26.2k
An cool vid of the 't'olo :p
What do you reckon the cars worth now?
Would anyone be interested? I don't wanna sell but just wanna know lol
Not a lot I'd imagine. If it was a proper setup then it would no doubt add value, but this setup could even lose the car some value. After all its not a case of if it goes pop, but when. That might happen in a few hundred miles time or it could happen on the trip home after someone's bought it, you'd have to find someone willing to take that gamble on it
Y don't you like this car Mclovin? There isn't a proper conversion is there!!!!! We have done the best we could! It's a cool conversion! I like been different! This car isn't going to go pop! You could say that about any car!
I have now covered over 200miles so Ye still running perfect!
I reckon this car is a real winner!
:lol:
I think this is a wind up man, surely?
It can't be for real.
I'm beginning to think the same max :lol:
But on the off chance that its not a wind up i'll still answer this
Just because there isn't a proper conversion doesn't mean people will be falling over themselves to buy a pikey turbo'd 1 litre that is going to go pop sooner or later. Yes you could say that about any car but this isn't a case of if, its a case of when. The more miles you put on it, the closer you get to the inevitable
You have apparently strapped a turbo to a 1 litre, its still got standard cr and standard ignition setup with no way to stop it advancing under load. This thing is probably detting its tits off under boost and sooner or later something will give. We've already seen what happens to a boosted 1 litre on standard cr and that had a much more proper setup on it
If you haven't seen the video, here it is
You asked a question and I gave you a answer, if it wasn't what you wanted to hear then that's unfortunate, but I'm not gonna lie to you to spare your feelings.
Any modified car or even a standard turbo car has the possiblies of going bang,
E.G: 21,000 mile 1.2 twingo turbo BANG
14,000 mile 1.4 seat ibiza twin charge BANG
the only reason you would need to change the CR is if you run alot of pressure through it but 'as it stands' 4 psi is a little more that a mouse's cough!
idealy we would stop it advancing under boost but 'as it stands' there would be no justification for doing this.
the car runs like a dream.!
No miss fire, no detting or any kind of engine malfunction what so ever on boost.!
i have now got the equipment to map the polo but i dont see any point in this as like i just stated the car runs mint.!
i am not however saying that if we uped the boost pressure then we would encounter these problems.
The KA ran 14psi before detintion started to happen so is now running 11 psi.
the ka does run a slightly lower CR so i think staying with 4 psi for the polo is safe.
we have run the polo up with the bonnet of and the easiest way to tell if the engine is 'detting' is if you watch the stability of it, and I'm happy to say it was as smooth as silk.
KA turbo conversions, that were made by a 'proper' tuning company (van aaken), did not use mapping or on boost retarding methods, just had a manual FPR with 1.7:1 ratio of rising rate pressure.
Having done my own version on the KA i have simply transferred the methods across to the polo :):)
so therefore the polo uses the same methods as the Van Aaken turbo conversions for the KA so is a 'PROPER' turbo conversion method :)
:):D:):D :):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:):D:)
As i said before, i have a vaccum advance pot you could use as its for turbos, it advances off boost and retards when its on ect
Hmmm, still not convinced :lol:
I'm really not convinced- but proof of the pudding is in the eating so when i actually see it giving it some then il be convinced it works.
All iv seen, is some blue silicone nose near the front of an engine.
A picture of a turbo.
And a video of an exhaust stuck out the side of a mk3 bumper.
I'd give you £200 for the whole car for the banter, anyone could do what you've done for the same amount of money; it really is nothing special!
200 miles? What's that really?! That could be 200 miles on tickover rolling around town!
You gave examples of cars blowing up at low mileage, I bet there's a LOT higher percentages of home brew turbo engines breaking!
Yeah :lol: I've typed "21,000 mile 1.2 twingo turbo BANG"
That means that these cars break a lot.
If your running 4 psi on the standard 9.8 compression ratio there should be no issue there. Phills 1.0 g40 was running alot more boost than that and none of the internals let go, just the headgasket.
Its not worthy of replicating as any form of kit though, as people have said its not what you should call 'proffesional'
Why not up the boost and enter it into ppc £999 challenge?
I'm sure my average fart is more than 4 psi
Just checked hes running 5-6psi, however still shouldnt cause the engine any damage.
Even 4 psi makes a difference, I've seen a k-series running 4 psi on standard compression (not cooled) from an eaton charger that gave a 20-30 bhp increase
Edited by shaun_89
now in the classifieds- cant have been that good!
It was just too good.
Quick sell it before it goes pop! :lol:
Swap the bottom end for an ABD and put a release valve in the intake feed, i recon that'll be alright.
You've fitted a rising rate FPR to sort of correct the fuelling for boost, and left ignition timing as is? But you can tell the engine's not detting because it looks stable when you open the bonnet? Don't know how many engines you've seen on an engine dyno detting away, but usually it has to be pretty catastrophic to make the motor shake around like a shitting dog. Ears and/or det cans, knock link kits and plug pulling are all methods of checking for det I recognise, never heard of the "bonnet of" method... With that CR you'd hit det limit before MBT anyway, so load it up and use your ears to listen for det - easy peasy.
What's the kit that you've bought to remap the Polo? The Bosch Mono-motronic ECU has no air mass/volume/flow/pressure inputs so can't cope with fuelling for boost as is, so am interested to see what your plans were.
Andy. Bit off topic, I've never heard a car thats 'detting' or 'pinging', what do they sound like?
my old mechanic told me about this you can hear them detting, i never could tho i used to have an ecu which flashed up, i think it was anything more than 30 knocks?? is it, but yeah he did say you can hear detting but cant remember what he said it sounded like :)
I wrote a big reply picking up on some of them points too but deleted it due to it just looking like I was picking on him or something :lol:
End of the day it doesn't make any odds if some "tuning" company sell kits like this, it doesn't make it any less of a pikey setup. Doing it as a bit of fun is one thing, but then trying to sell it on to some unsuspecting kid is another thing entirely
Edited by Mclovin
Ah men Guy I agree with you and tbh it doesn't look like this person can take criticism and dodges some of the important questions asked
Also there has been no proper evidence of the turbo setup and in his for sale thread still no pictures of it so how will a prospective buyer not know he is being conned for a start and how will they know its not a proper Bodge job like it looks which could be extremely dangerous if something happens while driving on the public roads
