LED replacement bulbs in a mk2f
Warm white is imo a much nicer look, as it replicates the colour, just brighter and less power consumption.
I have got some w5w tower less in the front of my daily, and they look great, o only had to ordr about 15 other that said they where warm white and turned out to be "xenon" or "power" white.
Also, to my above post about the break and tail lights, I didn't realise the mk2/3 lights where so small , so in fact the leds may work pretty well, as the bulb is central and would light up the whole thing. Where as on say, a 9n3, it wouldn't even light up half of it.
  • Replies 32
  • Views 5.7k
http://www.ultraleds.co.uk/led-product-cat...-44mm-long.html
I went for the 6 LED warm white one. It was a lot brighter than the filament bulb it replaced! I also got the equivalent 37mm one for the boot (saloons have a boot light built into the rear cluster!)
http://www.ultraleds.co.uk/led-product-cat...39-mm-long.html
http://www.ultraleds.co.uk/264-42mm-6-wa-s...warm-white.html
Gaz is this the correct one for the interior?
Are you handy with a soldering iron? How's about we make me a ciggy lighter bulb from an LED?
I trial fitted one of the bulbs Friday night. The light output was really good and it had a nice cool white (more "pure" than blue white) look to it
but the bulb is too long to fit the lens back over the top :( So I'm going to have to send it back and see if they have a shorter bulb
Edited by schneil
  • 4 months later...
An update.
I have now replaced the:
Interior light with a LED warm white festoon.(from ultra LEDs)
Number plate lights
Side repeaters
and I have some LED tail lights on order.
If anyone wants more details let me know
An update.
Number plate lights
Side repeaters
Yes please more info on what I should be buying ?
An update.
Ok I
Number plate lights W5W 8 LED
http://www.ebay.co.uk/itm/2-x-8-LED-501-T1...=item43a92b4781
I had to use the above as the other bulbs were too long (see earlier post)
Side repeaters
As above but in amber (I have smoked lenses, so used to have amber bulbs)
Side lights 233 5 LED
http://stores.ebay.co.uk/fizzmo-uk/BA9S-23...;_sid=138318779
The side lights were a little tricky to fit as the bulb took a bit of persuading to get through the hole in the headlight.
Ok many thanks boss :-D
