rear passenger footwell leak fixed
FIXED. :-)
I had a leak and water/fluid was collecting behind the front passenger seat in the foot-well. i suspected the rear door or the seal, the boot wasn't going to be it as the water would have dropped into the spare tyre well.
It turned out to be the rear wash/wipe pipe had unclipped at the push fit rubber hose connection. I have a 5 door hatch and the pipe is located to the left of the rear seat behind the plastic cover, about shoulder height. You need to remove the door seal, then the surrounding lower trim. You may need to remove the lower seat pad and tip the rear seat forward to release some parts.
locate the pipe and check it for continuity, i added some insulation tape around the pipe to help it stay together.
Ruined my underlay and light grey carpet, sourced a darker carpet so that's my next job after the rain stops.
I hope this is of some help to you guys. :thumbsup:
  • Views 737
