Water in boot. Leaking somewhere...help!
Hi all,
So, I first noticed that my back seats were slightly damp a few months ago and upon further inspection I found that the boot carpet was damp as well which then caused huge amounts of condensation within the car and patches of mould started to form.
I initially put it down to the fact that I had recently changed my rear light cluster and managed to lose the tightening screw, and as a result had to 'drill' a normal screw to secure the cluster in place. I figured that the seal wasn't tight and water was seeping in.
I bought a whole new cluster with bulbs and bulbholder and fitted it, I thought the problem had gone away but with the recent heavy rain it's come back again and now the boot carpet is pretty wet.
As you can see from the photo, underneath the boot floor there are channels which are quite full of water and I can't quite figure out where it's coming from, does anyone have any ideas as to where to look?
Thank you!!! This is driving me mad!
  • Replies 6
  • Views 5.5k
take the rear bumper off and look just below the inside corner under the rear light,,mine had the same problem i looked everywhere and relpaced all the seals and it turned out to be a small hole on both sides that was letting the water in may be the problem
I had the same problem and it turned out that the hose that feeds the rear wiper washer had come apart.
Guys,
Thanks for the suggestions but I don't think it's either of them
I took the rear bumper off yesterday and had a good look around and couldn't see anything that could be causing water to get in, and it can't be the washer hose as the water only gets in when there's been a lot of rain.
Any other ideas?? I guess it's one of those issues that could be absolutely anything!!
take lights off and put some silicon sealant on them, it stopped it on a few cars I have owned over the years that had water in the boot
Edited by shakennstirred
Yeah cheers, I think that's going to be my next step, I'm sure it's coming from the light cluster some how..
Take all the carpets and trims out and get a hose on it and sit inside untill you can see where the water is coming from.
