FK 6n coilover spring rates
Hi guys
I did some testing on coilover springs today, FK (high sport IIRC) coilover springs as fitted to 6n
Front spring marked 1866
measured
5.8kg/mm
5.9kg/mm
using http://www.dfaulknersprings.com/convert.htm
Means they are 330 lbs/in
The rear marker 2065
measured
4.78 kg/mm
4.84 kg/mm
4.87 kg/mm
it works out to be 268 lbs/in so 270lbs/in
the helpers are 95lbs/in.
hope this helps
if people want to send me springs for measuring like standard mk3 springs I'll happily check them out
  • Views 1.8k
