Breaking Polo GTI engine
Do you have a photo of the pipe you need? Or some sort of reference as all the pipes off it are just in a box of pipes.
  • Replies 40
  • Views 1k
Gearbox mount?
£10 + postage.
I assume you mean the one that goes onto the chassis leg?
Bump.
Still got>
- Entire car wiring loom (with key, ecu, steering column and transponder) - £50 delivered ONO
- Pedal box - £25 delivered ONO
- Block - £125 delivered ONO
- Starter motor - £25 delivered ONO
- Inlet Manifold - £25 delivered ONO
- Throttle body - £20 - delivered ONO
- Gearbox - £165 ONO
- Various hoses and pipe (all in a box so will need pics of very specific description on what you need as I don't know where they all go).
Hello pal.
Will that gearbox fit my 2000, 1.4(AUD) Polo? It currently has an ETD code box.
Many thanks.
Sean.
Yes it will fit but obviously the ratios will be slightly different.
It should be slightly longer ratios than mine I think. That's good because it would drop the revs slightly at motorway speeds.
Is delivery/courier possible? Would you be prepared to £160 delivered?
Many thanks
Edited by seanr68
ECU, key, transponder sold.
Still have the main wiring loom.
Block and gearbox still here.
Block is sold.
Still have the gearbox and the main wiring loom.
dont spose you have the crank sensor do you?
CHEERS
Do you still have the engine head?
Where you based? Ill have the gearbox if your nearby
Do you still have the engine cover and air-filter cover/top?
This is 6n2 gti avy engine? Exhaust manifold price?
Block is sold.
I'd appreciate an update on the block I bought. It's been ages since I've paid you for this and have emailed you as well as sent quite a few PM's.
I wouldn't normally post like this but I feel like I'm getting taken for a bit of a ride considering I've seen nothing and you've had my money ages. :doubt:
Block is sold.
I've received nothing, no engine and not even a PM or an email response to my messages so I've raised a dispute with PayPal now. It's a massive shame because I hate doing stuff like this...
