Chris Pinches mk3 Rally Project
i'm actually thinking i might not bother. I think it makes it look a bit fussy with the extra detailing.
Hopefully get the paddle clutch, and service kit for the 16v sorted soon, rebuild and drop the lump in over easter.
  • Replies 180
  • Views 50.4k
  • Guest vdub13
    Guest vdub13
    yep thats my car. she has been getting a make over lately!
ok some (slow) progress....
oh and i came across something rather special....
i just hope it fits!
VWM four branch?
10 points that man. VWM 4 branch manifold from S1600 6n2. no idea if it will fit inside a mk3 bay yet but worth a try.
Haha, what a guess, didnt even bother looking up the part number! Hopefully it wont foul the ARB, if it does.........then i guess its time for a wishbone conversion!
Looking forward to seeing this progress!
Matt.
car will have a wishbone conversion regardless at some point, once i've sorted the rear springs out and made some new front coilover struts (mine are somewhat battered)
Could still foul the subframe.
Then again, if you know what your doing, modifying the subframe shouldn't be much of an issue. Or if you know someone that can weld and bend pipe.
Block and cam cover look dead smart :)
cheers!
if i'm honest, the manifold looks huge in the downpipe section in photos, it's actually not that bad compared to a normal mk3 one - remember the mk3 downpipe goes 4-2 but the pipes sit diagonally. It'll be close for sure, but we'll have to see!
I know Dan (Renegade440) had to get his subframe re-done to miss the 4 branch on his afh.
That was a PPS Subframe. Not sure what PPP ones are like. If you did go PPS, i dare say Norman will have the measurements he used to re-do dans to miss the mani, so should be able to build it for a straight fit.
As toby said really ^^ Give me a shout if you need to check anything
Block looks good, really regret not doing mine gloss black. Ah well, plenty of time for it all to come back out again lol
i actually was very close to painting the block blue, but got given a tin of black engine paint the day before i painted it!
I'll be in touch once i actually get anywhere near putting it in the car.
I've just been fitting the pulleys for the cambelt kit and a new water pump, before covering it all up and heading back to uni for a few weeks. Will order a head gasket and a set of stretch bolts so i can get the verniers setup.
I'm also considering running a mk3 sump like heg123 did to maximise clearance.
  • 3 months later...
Well, i have eventually managed to sort out the head gasket, after having a bit of a nightmare having to get stretch bolts i've now managed to get the gasket fitted, the head bolted back on, new water pump, cam belt kit etc etc.
Just waiting for the sump to return, engine mount plate to be laser cut (see CAD drawing) which i'm going to put a captive nut on for the extra bolt in the engine mount
The next time i'm home i'm intending to strip the engine bay back as far as possible, finish stitching the legs and re-triangulate the bulkhead onto them
wow great job you doin mate
manifold! <3
:lol:
but seriously....
315777_10150344210470210_510515209_98079
300802_10150344210950210_510515209_98079
300886_10150344218190210_510515209_98079
fits like a glove. i have measured how much it extends from the block to try and measure ARB/SUbframe clearance
:unibrow:
that engine looks very sexy, especially with the fanimold on.
Lush!
Enging is lookin sweet cant wate to see it in :D
looking good, just noticed your from london, where abouts? you ever up the ace cafe ect?
Such a good looking engine!
if i have time i try to get up to ace, yeah. i actually live in shepherds bush.
just collecting more bits for a push on this over christmas. fuelling side is designed, inlet manifold in stock just need to order the bodies and the associated linkage, trumpets, injectors etc etc
ah only up the a40 then! i live by ruislip. maybe ill catch you around sometime!
whats spec injectors are you running mate? also what bodies?
Jenvey TS 40mm bodies, low profile so i can run the longest trumpets possible to bring the torque and drivability up.
I haven't specced injectors yet, as theres a fairly complex equation to work out whats required :cry:
  • 10 months later...
Updates needed!
Also i want one of those manifolds!! They hard to find or they off a standard car?
Nice engine mate! Manifold is really a beauty!
