mk2 polo G60 M/C conv parts
i am selling the parts that i used to be able to run a g60 22.2mm master cylinder in a mk2 thats non servo
so the shortened and re threaded pushrod with clevis joint and also the aluminium spacer block
both of these are straight fit so no modification required and means you can literally plug and play so to speak a G60 22.2mm master cylinder
improved breaking feel especially needed if your running a rear disc conversion or bigger front brakes
i have modified the pushrod by shortening it and threading it further up the shaft so it sits further in towards the pedalbox
worked perfect on my mk2 with a rear disc conversion and vw11's upfront you could really feel the difference over the standard m/c
i can also make the ally spacers if anyone wants one of these
I'm asking £15 or £20 posted for these bits
pedalbox in pics not included unless you want it then its yours free for an extra £5 posted ontop
  • Views 235
