sold
Blaupunkt boston cc22 stereo cassette car stereo as fitted to a lot of early 90s german cars. Std fit in vw polos made between 1991 and 1994. also found in some bmws and audis.
Made in 1994
Code is written on the top of the unit, although I have currently turned the code off, so shouldn't be needed (this is done by powering the unit up, whilst pressing buttons 1 and 4)
unit powers up, radio works, casstte deck is untested
4 speaker outputs, 5 watts rms per channel
balance and tone controls
It is a pretty basic unit, it does not have any pre-outs or aux in, so you won't be able to connect plug and play amplifiers or cd changers to it. It is in generally good condition. the cage is missing, as is the outer surround trim. Both could probably be sourced from blaupunkt or second hand.
£25 posted or £20 collected from chipping norton, oxon
Edited by g40jon
  • Views 208
