White Ibiza Cupra 230bhp
eat ibiza Cupra 1.8T 20VT
White
Great car to drive, handles amazing, pulls well all the way through the gears, never seems to run out of boost, needs to be driven to see how well it pulls. Is fairly good on fuel if your right foot isn’t to heavy, always run on shell V-Power. I serviced the car at 105000miles, changed the oil filter, oil, and spark plugs. Never had any problems, is a good strong engine and hasn’t been abused.
2001
around 108000 Miles
TAX Feb 2013
MOT Feb 2014
part service history Mostly at Seat
Central locking, Alarm, Remote start, Turbo timer.
K03 Hybrid turbo
New Decat downpipe
G60 Flywheel
VR6 Stage 3 fast Road Clutch
Forge silicone Tip
Forge silicone breather hose
Forge Dump valve relocation pipe
Forge adjustable actuator
Forge silicone coolant hoses
Forge Leon cupra large Inter-cooler
Forge SAI Blanking plate
Forge 008 Recirc valve
Forge induction kit
Custom 2.5" inter-cooler pipework
Air con fully removed
Remaped 230bhp
Powder coated blue cam cover
Powder coated yellow inlet manifold
Jetex cone filter
2.0 tfsi coil packs
S3 MAF
S3 Fuel pump
S3 injectors
Forge SAI blanking plate
Braided fuel lines
Battery relocated to the boot using 0 AWG cable
Forge Oil + water caps
Forge Washer tank
Forge coil pack cover
Chassis:
16” Rota Grid Drift on Yokohama Prada Spec 2
JOM Coil-overs
Poly bushed rear suspension
Big Brake Converstion Hi-spec Billet 4, 4 Pot Callipers on 312mm disks
Interior:
Fully stripped out
OMP reclining bucket seats
Short Shift gear stick
Dished steering wheel
£2600 ono.
07703515274
will swap for L200, bora tdi, audi tdi, 4x4 tdi, astra van cdti
Edited by plipman
  • Views 249
