GT Conversion almost complete! £250
As the title. GT engine and gearbox with loom, ecu with 8k chip(standard chip included), coil, throttle body, inlet manifold, starter, alternator, injectors, fuel rail with reg, all engine/box mounts, airbox and ducting. The engine is on roughly 90000 miles and came out of a running car which pulled well but I have no paper work with it.
Basically everything is there apart from the airflow meter, inline pump, exhaust manifold and maybe 2 of the 3 rocker cover bolts but may have some in the garage!
Will even chuck in a 5 speed antiroll bar and gt/g40 back box if needed.
Will upload pics soon but pretty sure you guys know what a 8v polo engine looks like.
Based in Norwich, Norfolk
Could bring to GTI springfest if you definitely wanted it!
  • Views 113
