the 1.6 afh saga continues.....
3 weeks why
  • Replies 114
  • Views 11.7k
got a deal with a manager at work to buy him breakfast in exchange for me swapping the engine at work, and 3 weeks is when hes next in on dayshift,
means i will probably have the most overkill engine crane in clubpolo history...
Bought a stainless 4-2-1 manifold woo!
So now i just need:
Alternator belt
6n alternator pulley
Thermostat housing - water pipe seal
Clip to hold thermo housing to water pipe
Replace conrod bolts
Weld other 2 inlet runners and file surface flat
Make up some inlet gaskets
You'd best be prayin it was your oil control rings filling the cylinder with oil that quick.
As said iv known a friend run without and was literally nowhere near as bad as what yours was
time will tell lol ./
Was his engine newly built tho? That could be the difference between an engine with no oil rings and a engine with shafted oil rings and everything else carrying general wear
A mate a a sierra with fucked oil rings and that smoked like a trooper, it used to use almost as much oil as petrol but it was piss cheap back then so he just kept topping it up rather than pay out for a engine rebuild
worst comes to worst i can ponce a cylinder head off a mate or something lol.
the state of them though, it werent good at all! may aswell have not had any.
Dunno was in a 1947 (I think) ford model A
so I'm finally back at work! :)
today i painted my spare cam cover to see if i preferred it to polished, safe to say it looks 10x better.
also took my spare cbr600s in with bike rubbers to make manifold, had to get the middle runners red hot and move them outwards a bit to make them fit. gonna make the outer runners shortly.
also had to butcher mark croxs alternator as whoever did the nut up done it far too tight and somehow squashed the washer into the pulley making it impossible to remove. hahahaa
so tomorrows plan is to paint up the alternator and engine mount and get them properly fitted.
Lol faces on carbs
engine mount and alternator sorted
Eric LOOOKS sick fam .. WE IZ GONNA BE 16Valvingz crew
Can we park next to each other at show and shine ;) lol
yer blud saaaaafe!!!!
more inlet progress
Looooong!
Looking good, making me wanna dig out my tin snips..
i chiseled mine! do it! lol
