My Polo Coupe S - Project Part deux
So am i going to have this same problem on the mk3?!
Did you have any issues with the drive shafts or they fine?
Well it depends on how the manifold is made, and Heg doesn't have a problem with them in his car. I know Bogg Brothers lost the template they had for the AFH engine as I had to send up my original inlet manifold so it could be the case that they lost the dimensions as well.
If they just go off at the same angle off the head then they will fit. I think it's that they set it to be at 45 degrees when the engine is vertical but on polos the engine is canted forward which means the carbs are at a much steeper angle, which means they go higher. I'm pretty sure that if the inlet manifold keeps the same angle coming off the head and not have the second bend then it will be fine and be an acceptable angle for the carbs to work.
Well I haven't attached the drive shafts yet but there wont be any issues with them as the gearbox hasn't changed so they should just slot back on :)
  • Replies 1.3k
  • Views 297.2k
  • mark_crox
    mark_crox
    I don't know what you mean......
  • Right a bit of an update is over due me thinks. Last August I noticed some rust under the sill trims.. Luckily is was only light surface stuff where there was a thin covering of paint. So after cryin
  • Cheers Simon. I does go well and the more miles I put on the engine the quicker it seems to get :) Not really done much apart from completing the 2000 mile european road trip. Hit Polo Treffen in Ho
hope you get it sorted soon mate
fucking amazin if i wer 2 put carbs on my 16v engine do i need da ecu? how does it work breal down to me lol?
What a build great mate
steveyB
8-)
Well I spoke to Bogg Brothers yesterday and they are basically just going to make them so the just come out from the inlet face in the initial angle. This should give them more than enough clearance and almost perfect working angle.
But this was a picture before I took them off :)
Its getting there slowly :)
its looking fantastic 8-)
how does the afh compare to the stock 1.3 block in terms of weight? are you going for a limited slip diff?
wish you good luck :-)
Cheers :)
to be honest I'm not too sure but I think its pretty similar.
Yeah I would want to get a LSD in the future but at present there is just not the funds to do it. So I'm going to see how it goes for now. I think LSD, Subframe and better suspension would all have to be done at the same time.
Well fitted the rad and pipes
and then I realised they were on the wrong way round.. :)
and lets just say that the engine compartment is a bit tight..
Yep the exhaust manifold is touching the rad shielding nothing a hammer wont sort out though :)
Also I changed the oil, plugs, oil filter and the Gear box oil. But to be honest I'm not sure why the stuff that came out was really nice and clear but as I had the stuff and I don't know if it ever had been done I thought what the heck
List of things to do:
-Fit the remaining Manifold nuts
-Tighten Driveshaft bolts
-Get some Trumpet socks
-Attach the accelerator cable to the pedal
-put in coil and wire up
-fix temp sender plug
-block off fuel return at tank
-wire in fuel pump and impact sensor
-plumb in fuel pipes
-wire in rev counter
-set the initial timing
-get it rolling roaded and set up
Dibbs on first passenger ride please mark!!
Great progress, love all the work you have done looks sweet! I have just got my AFH engine ready for my conversion, just wondered if anybody has any info on running standard EFI in a mk3? Cheers
Moza
the project is looking good mate
:) We will see what we can do..
Moza
Cheers, :)
Apparently its not too bad... saying that I've never looked into it. Probably the hardest thing will be is finding a Wiring diagram for the engine. :)
Tar Very much :)
Itsss back and it fits!!! :)
Got an insurance quote as well..... £540!!! which is more than my BM. so I'm going to have a phone around and see what I can find.
Right the list has got longer!
- Fit Manifold nuts
- Tighten Driveshafts
- Tighten Rear Engine Mounts
- Attach Accelerator cable
- Attach Choke Cable
- Fix the broken coil, Temp Sender and Horn Plugs
- Wire Fuel Pumps
- Fit Fuel Cut-off Switch and Power switch
- Buy Fuse holder
- Fit fuel lines to carbs
- Top up Gearbox oil
- Tighten Gearbox fill plugs
- Put the Spark Plug leads on the correct order
- Get and Fit breather filter for catch tank
- Shorten Radiator pipes
- Work out which way the pipes go to the heater box
- Change Brake Fluid
- Buy and fit new Speakers
- Fit Coil Earthing Strap
- Fit O2 sensor blanking plug
- Fit Anti roll bar and wheels
- Set Initial Timing
- Get to Rolling Road
Easy stuff!!! :?
Edited by max_crox
Forgive me a childlike...Woop woop wooooooop!!!! :-D :-D :-D
£540 that doesn't sound that bad if all the mod's and engine swap is declared
any way how old are you and what ncb are you useing for that car ??
Well I got another quote for £360.. which is much better :)
I must admit that a lot of the stuff in the picture is not actually connected properly.. I just did it so I could see how they look.. :?:
So its not running yet. I'm going to work on my list (see below) this weekend and then hopefully get someone who knows how to set the timing on engine to come over next weekend to help me do that. It then should give me 2 weeks to get it to Aldon for them to play around with.
It started with a list......
And I can now say I would gladly pay the 300 odd quid for a subframe as long as I never have to mess with the Bloody G-Larder arb blocks again!!
But....
Got the tyres fitted to my rims
And this is where my list currently stands as of saturday
Edited by max_crox
Well this is how the list now stands after today.
Fit accelerator cable is half ticked as its not done properly.. as you can see in the picture
The reason for this is the available pull on the carbs is less than what was on the standard engine. So using the standard point would mean the peddle would only go half way down or it would only come half way back, this set-up means I have full peddle travel. But I still have to work out a nicer set up... :-p
I've wired up and plumbed in the fuel pump and also fitted the fuel cut off switch(red button).
Painted the fuel pump/regulator bracket so it won't rust.
now the car is on the floor i have realised how low it actually is. Its great but doesn't half hurt you back bending over all the time!! :lol:
Edited by max_crox
i love this car and this topic!
cant wait to see it develop more!
LOVE THIS TOPIC !!!! that is one very tasty car :) *splat !!* lolz
did i see your name on the bovington trackday list mark? hopefully myself and 3 others will be there in a mk2 golf GTi, dark blue on sebrings :)
You might have done... :-D
Its going to be a dam good event, something that may not be repeated again... I'm really looking forward to it, it will be a bit of a baptism of fire for the car, If she is ready... hopefully firing her up on Sunday!! :)
make some videos of it and lots and lots of photos :-D
I'll Try :)
Gave it a clean today..
oh and....
:eey:
Not all great though, as I'm having a problem with the accelerator cable. Just touch the pedal and it shoots up to 4000rpm So I might be replacing the cable in a trial to get it to work properly with a mount point as close to the pivot as possible...
i want your wheels and down pipe lol lookin gd mate
could be the tiny throttle wheel, larger one might cure it, or custom accelerator pivot.
I'm very curious on the result on the road, have you driven it yet?
I'm curious as I'm planning on doing the same swap on my white mk2 gt :-D from all the engines that i have seen that are "not dificult" to fit on the mk2, the afh is the only one with bigger bore than stroke and the best choice to make a screamer I'm my opinion ;)
dont forget that you have lightened the flywheel, throttle responce is much sharper after that :)
i really love this and even to the point where iam looking through ebay for an engine! complete car for 350 accident damaged! intriguing! i have a mk3 loon at the mo, but fancy a coupe mk2/mk3 to do this with!
are you still without a servo?? bet that will make for some hairy moments!
good luck with the niggles.
