My Polo Coupe S - Project Part deux
You've got no fan on your alternator.... :?:
  • Replies 1.3k
  • Views 297.2k
  • mark_crox
    mark_crox
    I don't know what you mean......
  • Right a bit of an update is over due me thinks. Last August I noticed some rust under the sill trims.. Luckily is was only light surface stuff where there was a thin covering of paint. So after cryin
  • Cheers Simon. I does go well and the more miles I put on the engine the quicker it seems to get :) Not really done much apart from completing the 2000 mile european road trip. Hit Polo Treffen in Ho
Ummmm (looks at picture) .... nope.... I'm cool enough 8-) :)
work out your issue?
Edited by max_crox
Dont even go there!! haven't a clue why its out, think I'm gona end up stripping the alternator and building it back using bits from my spare (i.e the bit i chopped off)
Pain in the ass.
renegade ill post on yours, what i did.
been working on mine tonight, almost ready to go in now!!!
one question though, how did you manage to fit the mk2 starter!!!??? i spent about an hour trying to get it on, but it seems to foul on the block and it's about 5mm out of line with the holes in the gearbox? HEELLLLPPPP!!!!!!
Have a look at renagades440 thread. he has had the same problem with his starter. I guess I was just lucky. it bolted straight on.
Which one bolted straight on? The pre-'93 ones will not fit against the 6n block. The last MK2F's had unique starters and this must be what you have.
I just used the 6n 1.0-1.6 flywheel,also fitted to the Golf ABD,they all seem to be the same.
It came from the original engine from the car (1990 Coupe S). At the time I was fitting it I had no idea that there could be issues. So I must have just been lucky it fitted
very lucky mark! you stuffy so and so!!!
1.4 16v on carbs really put a smile on your face dont they! I've not had mine rolling roaded just a quick set up at work and it seems to fly! i just love second gear in it!
will you be at edition? would like to have a look around your car.
It is fun. :-D
Unfortunately I won't as I've just come back from a 1300mile round trip of Scotland with the car.. So a rest is in order :)
hey max well done i like the build, got plenty of pics here =) carporn heheh
keep up the good work and post some more pics or vids =P
cool ride mate just read the entire lot I'm fitting a gt motor in my mk2 saloon picking engine up tuesday just a question
if you dont mind i know its long ago but when you did the gt swop did you fit the mk3 gt fuse box.
me mk2 sallons a 1.0l so a bit weedy
its running 13 inch smoors very low retro rack etc ill post some pics
cheers gaz
cheers gaz
Hi Gaz,
Yep I swapped the whole of the wiring and the fuse box. The GT conversion is a good one to do :)
Quick update.
Well not really much to update. Car is going strong and have now done 4 track days with it.
Pictures can be found here
http://www.clubpolo.co.uk/forum/index.php?...=152947&hl=
The only issue has/is the fuel pump location with it being above the level of the tank and heat soak. Heat soak has been dealt with by some ducting and a fan.
I'm going to move this to under the rear of the car and it should sort it all out.
Did a week long camping road trip to Scotland in as well. And apart from an exhaust meeting ferry issue all was great!
looks like such a sleeper in the lastload of pics :D
love it :thumbsup:
loved this entire thread, looks like a quality car. nice one
Well its starting again...
So on the list of works to do:
Body Work / Interior:
Investigate any hidden rust under plastic covers. (Sills)
Know rust for repair;
Both rear wings and petrol filler location
Front wings (bolt on/off)
Rear valance
Small amount of surface on lower doors
Strip the sound deadening out
Re-carpet car
Build speaker pods
Replace leather gear gater and knob
Flock Dash (maybe)
Buy a bucket seat and subframe
Both road and track wheels refurbished
Re-Spray in original colour and re-add the pin striping
Chassis:
Fit lower subframe (not wishbone conversion)
Change all rubber bushes and mounts (they have had a hard life)
Wheel bearing
Build and fit roll cage with harness bar
Fit rear anti roll bar (if one gets made)
Engine:
Relocate fuel pump
Replace fuel lines
Cool Air feed/Airbox (Maybe?)
Check centre box for wear
Electrical:
Check the wiring looms.
Re-Wire fuel pump switch.
Re-Wire Radio and speakers.
Fit Fuel Pressure gauge
Re-fit Oil Pressure gauge
Started stripping the seats to make the sub frames
Take 1 seat
Put it on its back
Lift the plastic trim at the side and remove the clip
Pull it off the stub
Do the same on the other side and remove the back rest.
Undo the pin holding the seat cover at the back
go round unhooking the clips
Pull the cover and the sponge off
and here you go
Next just grinding off the welds to the internal sheeting and mocking some mounts.
read the whole thread and made an interesting read, top efforts mate and nice car, modded in all the right ways. audi rims make it look tough they suit it. makes me want to get on with mine mk3 poss afh it! rusts a pain i have same issues :-(
Cheers :)
Here are the results from the RR day at Aldon. Not bad :thumbsup:
so basically you've just got the tourque increase off the carbs as apposed to a power gain, interesting that.
Torque and power. The engine is 100bhp at the fly at standard.. this does 126 according to the RR :) Not actually sure what AFH produces torque wise as standard but this got 111lbft.
Edited by max_crox
I just put a downpayment on my mkii coupe yesterday and I've just read this whole thread. You, sir are an inspiration!
Thank you !! :)
hows the coupe then?
Thank you !! :)
lol @ 4:45am
She's awesome! I'm used to driving a mapped Leon Cupra R lowered with ARBs etc etc and I've never grinned so much behind the wheel! People actually let me out at junctions and wave and stuff! She's like new, I'm really impressed with her.
Actually, maybe you can help me with a suspension conundrum, I've been looking at different setups but don't want to lose all comfort as she'll be the daily and will have to do speedbumps etc. I can see that yours is probably a bit more of a track setup, but what would you recommend for a daily? I'm not afraid to spend a bit of money on it.
Cheers mate and sorry for the hijack!
Edited by EmDee
