My Polo Coupe S - Project Part deux
Cool.. you got a build thread?
Do you have the driver side or the passenger side? I've got 2 of the passenger side already so I might try and use bits on the drivers side.
The pads are just Roloc ones but its only used on paint and stones-chip stuff. On the under seal I use a paint removing disc on a drill like tool.
  • Replies 1.3k
  • Views 297.2k
  • mark_crox
    mark_crox
    I don't know what you mean......
  • Right a bit of an update is over due me thinks. Last August I noticed some rust under the sill trims.. Luckily is was only light surface stuff where there was a thin covering of paint. So after cryin
  • Cheers Simon. I does go well and the more miles I put on the engine the quicker it seems to get :) Not really done much apart from completing the 2000 mile european road trip. Hit Polo Treffen in Ho
I thought I had a drivers side but its been that long since I got it I had to check and it is a passenger side one too!!
I have been using the Roloc ones, do you know the part number for the paint one you use. If i'm thinking the same its a redybrowny colour quite hard and course?!
No build thread yet, taken the pics but nothing up.
I meant to look at what kind of Roloc that I'm using but I totally forgot. Will look next week for you :)
New Drivers 1/4 panel ordered from VW might be here in a month or so as long as they don't turn around and say its obsolete.
Did some more work on the drivers sill.. and found a hole :(
also started to get the surface rust off the bonnet
and the boot where someone decided it would be good to screw the number plate on with self tappers!
God that looks pretty bad.
Was it all hidden? have you never noticed it before?
Nope didn't know it was there as it was under the under seal and under the sound deadening. But it can all be fixed.. just going to take it back to see how far it goes.... eeek!
Hmm that's worrying.
My mk2 has simular sort of rusting around the rear aches, at the bottom. I wonder if it shares the same corrosion else where. :crybaby:
Did you get my PM mate? Could really do with knowing.
Max
Quite possibly.. but if you can't see it its doesn't exist!
Will respond now..
Picked some of these ramps up today from the NEC Classic Car show
Should make putting the car back together and maintenance a lot easier.
And also the car is officially TrackCulture's Project of the Week :)
http://www.trackculture.com/2010/11/14/pro...2-polo-1-4-16v/
I've started using the 777F 80grit which are ace at stripping the sealer and attacking any rot areas for stripping back.
Bad find on the rot but as you say you never know what your going to find when going all the way back!!
Nice ramps too
Well.. its been a good week.. Roll cage purchased should be here Monday
Phoned the dealer to expect them to say the 1/4 is obsolete but to my surprise that it had been there for a week and they have been trying to get in touch with me. (They had the wrong number). So loaded it on my new multi purpose vehicle!
the panel
Today I was taking more of the driver sill off and cleaning up the hole in the floor!
Weekend off next week as its Thanks Giving!
This was waiting at home for me at lunch time....
Any info on them ramps?
Supplier, price etc?
Look sick!
Means you can get the car, on ramps with zero engine.
Look sick!
Exactly! :)
From CJ Autos
normally 399 + Delivery + VAT but we picked them up at the NEC Classic car show for £399 all in.
How much did the panel set you back out of interest?
I've been on vagcat and a now antiquated version of ETKA 7, and it still showed quite a few panels as still available, allbeit at quite high prices!
I've been on vagcat and a now antiquated version of ETKSA 7, and it still showed quite a few panels as still available, allbeit at quite high prices!
It was £280ish. So rather pricey but it means the work to fix all the rust will be easier now we can take the panel off the car.
When to the trimmers today..
Humm choices! :)
An Example of Bromsgrove Auto Trim's work
Cleaned up the hole and removed the sound deadening
made a plate up
cut the hole bigger
made the plate up for the inner sill
And this is where I spend my Saturday mornings!
Them seats! How much was that??
M
Coming along very nicely :-).
Cheers. its getting there slowly :)
Seat re-trim like that would be round £500ish + VAT i think but its best to give them a ring to get a proper quote.
Looking to get the car booked in for March which gives me to the end of Feb to get the body work done and painted..
Certainly do-able in that time frame.
I was lucky one of the lads at work was happy to take my Coupe on after work, and over a weekend. We got plenty done, quickly.
Looks good Mark, what are you getting retrimmed?
How much did you pay for the cage if you don't mind me asking?
Cheers.. well it will be the whole of the interior. Seats, door cards, headlining and carpets.
The cage was off eBay so it was rather cheap! :-D
What fuel pump is this running Mark?
Ahh ok
Reason i asked was Higgo said you where running a R1 fuel pump. Must be mixed up with someone else, or i just mis-heard lol.
Just realised how cheap that one is, compared to a facet. any difference? Looks the same all but the stickers lol.
Edited by B-shaw
